boost power
Old Apr 6, 2006 | 06:51 AM
chrisblueevo's Avatar
boost power
How much horsepower does each pound of boost make on a stock turbo
Old Apr 6, 2006 | 06:58 AM
Curt@MrLed's Avatar
Former Vendor
agghh.. that question is impossible to answer as every car is different.. get it dyno'ed.
Old Apr 6, 2006 | 08:14 AM
Boosted Josh's Avatar
in general 1 atmosphere or 14.7 psi will increase the car's output by 100%. So in a perfect world a car that makes 100 hp NA will make 200 hp with 14.7 psi.
Old Apr 6, 2006 | 08:30 AM
Warrtalon's Avatar
It's usually 10hp per pound, but that depends on the car, the mods, and the efficiency of the turbo.
Old Apr 6, 2006 | 08:32 AM
deadbeatrec's Avatar
well as long as u dont run out of octane
Old Apr 6, 2006 | 09:52 AM
steevo's Avatar
That's cool. That means I may have gained as much as 80hp just fixing my boost problem with a mbc. I was running 11psi for almost 3 months without knowing it. Now I'm at 20.5psi. Talk about bang for the buck for me!!!
Old Apr 6, 2006 | 09:58 AM
Warrtalon's Avatar
Actually, yes, you probably did.
Btw, how could you not know you were running 11psi for 3 months? Don't you have a boost gauge?
Old Apr 6, 2006 | 10:02 AM
steevo's Avatar
I didn't at the time because my service manager actually told me it would void my warranty!! I said screw it finally. Then the guy who installed the gauge said "Yep, perfect 11psi...I've never seen a 4-banger do that!" I was like, dude wtf?? Im supposed to be hitting much higher. So took it to Topspeed and you know they figured it out in like 1 minute. That's my story! It's been awesome ever since
Old Apr 6, 2006 | 10:04 AM
Warrtalon's Avatar
MMmm, k, so the service manager said a boost gauge, which is a safety monitoring device, would void your warranty, but he didn't say anything about your MBC, which can blow the engine if used improperly? Sounds fishy. Regardless, glad you finally got a boost gauge and saw what was happening. I'm amazed at how many people buy used Evos and don't realize they are running around with 11psi. It happens all the time...and they buy the thing without even realizing how slow it is, haha.
Old Apr 6, 2006 | 10:10 AM
steevo's Avatar
Yeah...I bought it used, had it serviced at Mitsu under warranty, and the Service Manager said ANY mod will void my warranty there. This included even a boost gauge or turbo timer! I was shocked. I asked about a boost controller after that, and of course, he said no mods at all. Yeah, it sucks for people like me with the 11psi problem. It should be a sticky for new used Evo owners. What really sucked for me was that Mitsu told me my car was completely stock and running perfect. When in reality it was hitting 11psi, had 272's in it, and an upgraded clutch. What dumbasses! I have been going to Dyno4Mance now for all maitenance.
Old Apr 6, 2006 | 10:14 AM
Warrtalon's Avatar
So you didn't have an MBC problem, then, but you fixed the problem by installing an MBC. I thought you originally said you had an MBC problem that was causing 11psi. Basically, you got a used Evo that used to have an MBC, then when the original owner put it back to stock, he didn't properly re-install the stock boost system. He probably used plain vaccuum hoses without the restrictor pills.
Glad you're fixed now. Didn't you say TopSpeed fixed you?
Old Apr 6, 2006 | 10:17 AM
steevo's Avatar
No, the MBC fixed my problem. The problem was the previous owner did not put back stock boost lines on. I could have fixed my problem with stock boost lines, but after all that with Mitsu, I said screw them.
Old Apr 6, 2006 | 10:19 AM
steevo's Avatar
You beat me to it! Yeah , Doug at Topspeed fixed it. They are awesome. So is Dyno4mance, which is only 30 minutes away.
Old Apr 6, 2006 | 10:21 AM
Gmvehar's Avatar
This is true, although I believe once your boost gets so high you will not see as great of gains. For instants changing your boost from 20 to 24 pounds wont get you 40 hp.
Old Apr 6, 2006 | 10:27 AM
Warrtalon's Avatar
Changing from 20-24 on the stock can very well give 40whp. I know, because I've done it and proven at the track. You can prove it on a dyno, too.
However, you're just repeating what I said in the quote: IT DEPENDS ON THE EFFICIENCY OF THE TURBO. I already made that point. From 20-24psi, we can gain 40whp, but from 24-28psi, we can't.
