more valve train noise after new exhaust manifold?
Old Apr 10, 2006 | 07:37 PM
bigchris2000's Avatar
more valve train noise after new megan exhaust manifold?
I was wondering if anyone else has had more valve train noise when replacing the factory exhaust with a megan manifold and o2 housing? I did both of mine and it sounds like pebbles are in my down pipe. I cant find any leaks. I maybee going back to stock it sounds so bad. I dont hear it while driving only at idle.
Old Apr 10, 2006 | 07:39 PM
Lancematic's Avatar
Sounds like you may have a leak somewhere. Did you replace all the gaskets?
Old Apr 10, 2006 | 07:40 PM
Yes I did.
Old Apr 10, 2006 | 07:45 PM
Lancematic's Avatar
What I would do is let the car be cold, mix up some soapy water, and put it one the part of the exhaust that my be leaking, most likely O2 to downpipe, then watch if it bubbles, or just try to feel around for exhaust leaks before it gets too hot again<----how my lazy self would do it.
Old Apr 10, 2006 | 07:50 PM
Thanks I will try that.
Old Apr 10, 2006 | 08:18 PM
EVOWHT's Avatar
I just did the same swap, and I hear the extra noise too It might be normal, but I don't know
Old Apr 10, 2006 | 08:31 PM
Does yours have the same sound? I have comp 280 cams so mine, im sure is worse
Old Apr 10, 2006 | 08:33 PM
I hate to say it but im glad im not the only one. I just tried the soap n water method and found no leaks. Im suprised no one else has said anything about this. My car sounds like a junker now.
Old Apr 10, 2006 | 08:36 PM
EVOWHT's Avatar
I am still on stock cams. It sounds like there is something in there rattling around! But I didn't replace all the gaskets, I thought since there were metal they could be cleaned and reused! I will be feeling for leaks tomarrow so we will see!
Old Apr 10, 2006 | 08:37 PM
I replaced all my gaskets and mine has the same sound you are talking about. thanks for the reply and good luck
Old Apr 10, 2006 | 08:39 PM
EVOWHT's Avatar
u too!! What exhaust do you have??
Old Apr 10, 2006 | 08:41 PM
Dc down pipe with no cat and Greddy ti
Old Apr 10, 2006 | 08:43 PM
MalibuJack's Avatar
Tubular headers tend to have a "Plinky" sound more than the cast iron exhaust manifold.. if your not finding any exhaust leaks, then what your hearing is probably normal.
EVOWHT's Avatar
Mine is AMS 3'' TBE w/testpipe! Maybe someone else will respond, and that use know something!
Old Apr 10, 2006 | 08:46 PM
EVOWHT's Avatar
Wow, before I even finished my statment! Thanks! Most of the videos I see of evo's with the aftermarket manifold, do seem to be alittle pingy
