? for the drag racers
Old Apr 12, 2006 | 12:17 PM
Warrtalon's Avatar
Straight up 4 wheel spin doesn't damage the tranny like wheelhop, of which I get none.
Old Apr 12, 2006 | 12:42 PM
fransevo's Avatar
What about the clutch? And what RPM's are you launching at? Thanks Warr!
Old Apr 12, 2006 | 12:50 PM
chuntington101's Avatar
as for wheal spinning a four wheel drive yes you can and you can do it a lot!
i have seen some mad WRC guys doing crazy stuff!
Chris.
PS. go for sticky tires and not too many rpm!
Old Apr 12, 2006 | 12:58 PM
jrsimon27's Avatar
well my case is as follows i do 7600rpm launches with 35psi on my tires and i do 12.2 on the quarter mile stock clutch ,stock drivetrain just as japanese do it and nothing has happen to my car it has 10000miles on it! what i think is that if you get wheelspin you will save your drivetrain!!just my case!
Old Apr 12, 2006 | 01:15 PM
Ivan_C's Avatar
Actually, raceboi, I do a 4wd burnout each time before I launch even with pretty low amounts of HP/TQ. You just have to overpower the tires, wh ich can be done with a high enough RPM launch. I don't do a stationary burnout, but I spin all 4 and move forward towards the line to shoot off all the dirt, gravel, and water.
Then, I stage and launch without spinning.
Yep I'm right there with Warr. Nice burnout to clean them off and put just a little heat in them. I have video of me doing them since 04.
Ivan
Old Apr 12, 2006 | 02:14 PM
Warrtalon's Avatar
Ivan
And fwiw, I didn't start doing it until after seeing Ivan do it. I used to do it on my DSMs, but never bothered on my Evo when it was lower-powered. As I got to the point where I started having wheelspin problems, I started doing the burnout to prepare the tires for a sticky launch.
Old Apr 12, 2006 | 04:28 PM
4TUN8's Avatar
Yeah I remember Ivan's 4wheel burnouts
Old Apr 12, 2006 | 08:40 PM
DragNRacing's Avatar
I have also found that burning out usually gives me at least a tenth on the 60'.
Here is a video example.
