i put 87 in my evo!!!! am i in trouble
Originally Posted by ksattic
I had to put a gallon of 87 in my car once when I got stuck in the middle of nowhere. Some places in Wyoming *only* have 87! Never again.
What makes me laugh are the people who swear that there is no difference between the grades of fuel.
Originally Posted by Dave2
get 3 gallon of 100 mix it up, then you will be fine. Octane booster only raise up 0.1 Octane
Originally Posted by Richard EVO
Dumb schmuck.
Stay the hell out of the throttle. No big boosting. Drive it like an old lady going to church on Easter Sunday. Better yet, siphon it out and use it to torch your neighbor's STi.
Originally Posted by evo4g63awd
no it just proves that you cant trust just about anyone with your car....
If you have no way to empty your tank by siphon/dropping it, take that drive to the Shop 40+ miles away staying out of boost. Once there you should have burned some gas along with any you already burned. Get some 100+ octane (higher the better to offset the 87) there and fill it up and drive easy till you refill again.
dotn use octane boost. Also you should be fine - if you are runnign a non-flashed stock ecu- your ecu will jut revert to the map with lowest timing and a richer AFR. Just dont do WOT runs all day long - go make some trips and burn it off
