i put 87 in my evo!!!! am i in trouble
Old Apr 14, 2006 | 07:57 PM
  #46
sleet's Avatar
Originally Posted by ShiftySVT
The computer would detect detonation and retard ignition timing resulting in a loss of power, but no damage to the engine.
Good to know it won't cause damage atleast.
Old Apr 14, 2006 | 08:02 PM
  #47
jj_008's Avatar
Originally Posted by donmeca2020
wow, that sucks.. i would just drive under no low boost till it runs down and then put some 93 in her.
+1. It's not a big deal.
Old Apr 14, 2006 | 08:03 PM
  #48
donmeca2020's Avatar
Originally Posted by Stinkapuss
Drain it. The dealer I bought my car from fill it up with 87 octane when I bought it. I made them drain all of it.
the guy tried doing that also, but when he went in to go pay at the gas station, i clicked the 93 oct instead.
Old Apr 14, 2006 | 09:02 PM
  #49
Tonz of fun's Avatar
Originally Posted by 4 Wheel Slide
my gf put it in when i went in to get a 12 packer, this proves beer is bad for ya lol
Fire her. She is done. Tell her shes fired!!!
Old Apr 14, 2006 | 09:07 PM
  #50
Turbolover's Avatar
Old Apr 14, 2006 | 10:47 PM
  #51
Jennifer626's Avatar
Your engine will ping
Old Apr 14, 2006 | 10:49 PM
  #52
kErViOsVIII's Avatar
stay off the boost and you should be fine
Old Apr 14, 2006 | 11:55 PM
  #53
EvoRecordSetter's Avatar
+1
if you know where to get race gas, mix some of that in... get the octane up!
until then, avoid hills, and dont boost! maybe even syphin the gas out.
Old Apr 15, 2006 | 01:33 AM
  #54
Tureno-AE86's Avatar
lol just take it easy dont spool up and ran the tank out all the way
i remember i was able to drive 78 miles b4 my 05 ran outta gas i do that with
all my cars 1 time to see how far i can reach incase of an emergency
Old Apr 15, 2006 | 08:30 AM
  #55
IXmr321's Avatar
go over to orlando speedoworld and put some 110 in it and raise the overall octane level in your tank.......and it will smell good
Old Apr 16, 2006 | 09:51 AM
  #56
Zander478's Avatar
Old Apr 16, 2006 | 09:52 AM
  #57
Zander478's Avatar
i turned the boost down to next to nothing...and stayed out of boost on the way home... so idk....idk how to syphon it out...but im gonna call one of my "shady" friends
One of your shady friends, thats classic,
Old Apr 16, 2006 | 09:57 AM
  #58
TTP Engineering's Avatar
Pull off the WG arm and you will have zero boost. You can go WOT all you want after that. Low compression pistons and no boost means you could likely spray a 35 shot and still be ok.
Old Apr 16, 2006 | 10:08 AM
  #59
dsmfan95's Avatar
Originally Posted by itzwolf
If you have no way to empty your tank by siphon/dropping it, take that drive to the Shop 40+ miles away staying out of boost. Once there you should have burned some gas along with any you already burned. Get some 100+ octane (higher the better to offset the 87) there and fill it up and drive easy till you refill again.
You can unhook the return line and put it in a gas can then let the car run itself nearly dry. That's how we did mine on the dyno, so we could do a race gas tune.
Old Apr 16, 2006 | 10:10 AM
  #60
Sharkbite2000's Avatar
You let your girlfriend drive your car ? then good for you !!! she should of put in desiel fuel instead you will run alot better
