hid one side is not as bright
Old Apr 16, 2006 | 04:45 PM
evodude9's Avatar
i've just installed a hid kit in my evo 9 and i've noticed that the right side is alot dimmer than the left side.
Just wondering would putting a grounding kit solve this problem.
Old Apr 16, 2006 | 07:42 PM
03redtype-s's Avatar
I highly doubt putting a grounding kit in would take care of the problem. You might contact the manufactuar and ask them if its normal which every hid kit that i have had and ive had several it shouldnt be like that!!!!! JIt might even be a problem wikth the ballast!!
Old Apr 16, 2006 | 07:47 PM
AznX TL's Avatar
is your evo RHD?
Old Apr 16, 2006 | 07:53 PM
evodude9's Avatar
my car is a rhd one. u're probably right it might the bulbor ballast.
bit odd that they both lit up though, looking head on they look just as bright but at night u could tell that only the left one is actually litting up the road.
i also tested it out by unplugging the left side and only using the right one. i couldn't really see anything on the road even though it was on.
Old Apr 16, 2006 | 11:18 PM
MRCole's Avatar
Did you change the headlight out at the same time, or did you just add the bulbs, ballast, etc? Reason i ask is, HID's need some sort of projector (not just any factory projector) to cut the light beam, project a clear beam and such. Check the aiming against a white wall and see if it is off, or a different color and what not. A guy on here, posted a similar question about his kit. See if you can find it. Or maybe someone else will link it.
There is a write up in the how to's section on how to add true HID's to non HID.
Old Apr 16, 2006 | 11:26 PM
4WS Tuning's Avatar
put the car against a wall and see if they are leveled the same....maybe its aiming toward the ground too much, so it appears to be dimmer.... that would be my best guess
Old Apr 17, 2006 | 03:20 AM
evodude9's Avatar
i've line it against the wall and also even line it even higher than the left side but it made no diff.
it's an actual hid kit with ballast ignitor and bulb
Old Apr 17, 2006 | 07:01 AM
AznX TL's Avatar
isnt the right side dimmer so it doesnt blind the people on the other side of the road?
Old Apr 17, 2006 | 07:05 AM
donmeca2020's Avatar
could bwe the bulb also if you installed a aftermarket kit. that happen to me and one was a different putput and color. i just returned it to who i bought it from and got the correct one.
wsutton
Apr 21, 2017 01:38 PM
Ducky077
Evo X How Tos / Installations
Oct 13, 2016 06:12 AM
dhonda
Jan 9, 2016 09:51 AM
slatermvp
Mar 13, 2011 08:21 PM
erniebu
Apr 21, 2010 03:41 PM
