Greddy type-s bov has flutter problem
Old Apr 29, 2006 | 07:03 PM
bigbadbob2k2's Avatar
If anyone has read my other post, I have determined that the car is set up for recirc. The problem is that when at highway speeds, if I accelerate then let off the gas, the BOV flutters.
I have read that the TYPE-S should have a different spring installed to work properly, but since it came on the car (I bought it used) I have no way of telling if this mod was done. I am thinking about going with a different BOV.
The car also has an aftermarket Upper intercooler pipe ( I think it is an AEM, it is red in color. . .), but that would not be an addition to the fluttering problem, would it?
So, if anyone has a thought on how to fix this BOV (i.e. how to tell what spring I have or where I can order the correct spring from, or how to tune it) please let me know. Thanks.
Old Apr 29, 2006 | 07:20 PM
Schuyler's Avatar
Well - I'll be gentle.
I used the "search this forum" button and used "greddy bov flutter" as the terms and came up with this:
https://www.evolutionm.net/forums/sh...dy+bov+flutter
Old Apr 29, 2006 | 07:23 PM
Evoryder's Avatar
my guess...prob have both springs installed ...plus tension is tight... either...loosen bolt on top or remove smaller spring...type s dismantles very easy...if you have trouble getting bov off...you should prob have someone else do it.
Tools needed to dismantle type s "allen wrench"
tools needed to adjust tension... "allen wrench + small wrench to loosen nut"
tools needed to remove bov... wont list
Old Apr 29, 2006 | 07:32 PM
Good solid answers to my questions. MUCH appreciated. I also came across another thread with other search words and actually apoligize for the post, lol.
thanks for not flaming nonetheless.
I will however post results after the spring mod.
cheers.
Old May 4, 2006 | 08:34 PM
I did the single spring mod and it completely fixed the problem. The BOV still holds boost np, and is quite a bit quieter too.
mikemaccarrone
Dec 13, 2014 10:43 AM
zenoise
Nov 15, 2012 07:59 AM
AlwaysinBoost
Dec 28, 2006 05:45 AM
Hong Kong Evo
Jan 16, 2005 07:47 AM
EVO VIII Chris
28
Jan 10, 2004 01:13 PM
