Guages confusion!
Old May 6, 2006 | 02:35 AM
Waz996's Avatar
Guages confusion!
Ok here's the deal:
Am getting 3 Defi BF gauges and confused on which is better. Knowing the first will be a Boost, what will the other two better be out of the three following and why!
- Oil Temperature
- Oil Pressure
- Water Temperature
Car will not be circuit tracked, more 'attacks' and 'short races'! ;-)
Thanks,
Wael
Old May 6, 2006 | 02:37 AM
smokedmustang's Avatar
Oil pressure, and I would get a AEM UEGO gague. (A/F monitoring device) . I can't answer why, its too early, and I need more coffee in me for that.
Old May 6, 2006 | 02:49 AM
Waz996's Avatar
Hey!! Oil pressure ok.. what about the third one!!!
Seems u need that coffee reaaaal bad!!! :-)
Wael
Old May 6, 2006 | 03:06 AM
Wael
Had a cup, I would go with oil temp. because you have the water temp on there stock in the dash correct? I am starting to wake up now, will return after 3 more cups!
Old May 6, 2006 | 03:11 AM
XK120's Avatar
Isn't the stock water gauge more of a dummy gauge?
Old May 6, 2006 | 03:47 AM
Yeah I think you are right. I was told the top 3 most important are:Boost/oil pressure/Air-Fuel gauge. thats what I have always had. dont know the importance (above the 3 I listed) of these other gauges. just my 2c
Old May 6, 2006 | 04:10 AM
Waz996's Avatar
I thought the oil pressure is somehow related to the oil temperature.. the reason being that if oil temperature rises, the pressure will be less /or/ if the oil pressure reduces, that would be due to a high temperature...
Dunno.. i'm swaying with thoughts!
Wael
Old May 6, 2006 | 04:45 AM
evokw's Avatar
I say go with Boost, oil pressure, and oil temp. You already have water temp so you dont need it. And the oil pressure is really important it tells u the health of your car. I used to drive a land criuzer that had a oil pressure guage and i used it alot, it tells you alot.
Old May 6, 2006 | 05:55 AM
hotrod2448's Avatar
I would go with boost, oil temp, and either fuel pressure, EGT, or AFR.
By the time you notice you have low or no oil pressure it will have already eaten itself so, pretty much no need for that one.
I like having something to monitor the fuel system with. Fuel pressure is the least effective but, is better than nothing.
EGT's and a wide band are nice but the install might be a little more than your average DIY'r is ready to tackle.
Old May 6, 2006 | 06:26 AM
cdavy's Avatar
Registered User
I think you are better off with an oil pressure gauge as you can actually save your motor (if you pay attention or have a warning gauge) over the light that comes on when it's WAY too late. My path is Boost, EGT, AFR, oil pressure and I will add water temp later as well. Outside of that I will add an volt/amp meter for the electrical side of things.
I am not sure what oil temp buys us, anyone? Would like to know the value of that.
Old May 6, 2006 | 06:39 AM
hotrod2448's Avatar
You shouldn't get into much boost before the engine is warmed up. Oil and water warm up at different rates so, that's one thing an oil temp gauge does. It is also a good indication of how hard your engine is working. More stress= higher oil temps.
Old May 6, 2006 | 06:49 AM
trinydex's Avatar
if you serach you'll find another thread just like this one. but i'll put in my opinion cuz it's very well accepted by people that do circuit track and if it's good for them it's likely good for something less enduring.
water temp is the fastest temperature response, barring egt but egt doesn't always tell the whole story and a water temp WILL. when water temp goes danger you stop or your engine will stop for you. PERIOD. egt goes up... you don't know if you went rich, or if your ecu pulled timing and dumped fuel... etc etc etc.
oil pressure, cuz no temp gauge will tell you what your oil pressure or any other pressure is for that matter. water pressure is also important but you'll likely know when you lose pressure there cuz the coolant will make it visual.
boost, you need this only for the peak warning. and that said... it's not even that useful because it doesn't tell you how much mass you're moving which means cold days only show high mass as big boost spikes. otherwise you could be running dangerous lean and not even know it.
that's what afr is good for. but i wouldn't get a uego, the voltages on it don't go down low enough for some applications of nitty gritty logging and switching.
what would i run?
zeitronix wideband with map and egt. digital display shows you all these non alerting parameters. you can watch your afr every once in a while... won't kill you... you only need to watch it on those cold days, like i already mentioned.
and defi bf water temp, oil press and boost.
Old May 7, 2006 | 12:25 PM
ford381stroker's Avatar
oil pressure (cause you wanna know if your oil pump is bout to go)
water temp (cause you wanna know if you are about to cook your motor)
Old May 7, 2006 | 12:30 PM
cdavy's Avatar
Registered User
Too bad there is not a dual gauge that does oil pressure and temp together (that I know of). It seems like it would make sence to only tap once and record both off once sensor... Anyone know of such a gauge?
red97rum
Sep 4, 2016 11:22 PM
TurboWill
54
Mar 25, 2014 08:12 AM
jameswwt
Jun 10, 2011 11:12 AM
MaxKanisha
16
Jul 17, 2007 05:02 PM
zmeli
Oct 21, 2006 11:48 AM
