Project: EVO-500. And so it has begun.
Old May 10, 2006 | 07:49 PM
910clubs's Avatar
nice good luck with the project!
Old May 10, 2006 | 07:52 PM
App420's Avatar
stew, i asked before but where in ct are you from? i think i saw you on route 25 once
Old May 10, 2006 | 07:57 PM
Stew's Avatar
Originally Posted by Andrew LB
Hey Stew. I tried getting a hold of you a while back regarding my brother in law and unfortunately when he made some calls, it turns out that they all think its a clear case of running lean due to your mods. It sucks... i tried.
I hope i'm not left out on a limb when i mod this car to hell.
Thanks man, I appreciate the effort. Even with the white residue in the O2 housing, I'd like to know how they thought the car was running lean from what they saw. Lean conditions would cause detonation long before a rod nut backed off in perfect condition. meh.
I'm from southeast CT, I don't think I've been over on rt. 25 with the Evo yet.. What part of CT are you from?
PhoenixEvo's Avatar
Originally Posted by dridge11
So you're going to go with a "Smithwick Injection System" rather than "Alcohol Injection". I've hard that's a good setup. Nice picks BTW! Good luck!
hahahahahahahahahahhahahahahahahahah man i laughed so loud when i read that!
Old May 10, 2006 | 08:16 PM
Stew's Avatar
Got a few more pics from tonight. Basically removed the FMIC, oil cooler lines, clutch lines, shifter cables, battery/tray, and the rest of the cables on the wire harness.
Naked
Transmission tweaked a bit when she blew eh?? This bolt was the top middle transmission bolt
Nice crack on top of the transmission. Looks like Shep may be getting this tranny to fix before re-install
Clean engine bay. As soon as the axles are out, tranny, x-fer case and motor are ready to be pulled
Tomorrow the axles get removed, I'm shooting to remove the big components on Sat.
Old May 11, 2006 | 09:59 AM
bolsen's Avatar
Awesome, I love big projects like this
Is that an actual crack? Or is it just from the casting?
Old May 11, 2006 | 10:06 AM
deadbeatrec's Avatar
cant wait to see more progress and it done. already done almost 180 in your R32 so what are we shooting for here, 10 second with 135 traps?
Old May 11, 2006 | 10:28 AM
Stew's Avatar
Oh thats a crack alright. Happened when one of the rods mashed a softball sized hole in the back of the block and cracked off a cast piece [from the block] where the upper rear most tranny bolt is located.
10.99 or better in the 1/4 would make me super satisfied. Building mostly for Auto-x though! Overall I would love to accomplish a low [atleast faily low] spooling 500 whp turbo that will be easy to handle around an Auto-x course, is a menace on the track, and produces anything in the 10's on the drag strip. That would be the ultimate street/track setup. Wait until I finish the engine and get to the suspension setup. hehe.
Old May 11, 2006 | 05:22 PM
sonicnofadz's Avatar
I've had a similar crack happen to me before on a awd DSM tranny. I had to replace the tranny. I do not think that tranny can be fixed, you would have to re-weld the piece back on, but it might break again since welds generally aren't strong enough to hold this type of load. Your block looks exactly like one of my DSM 6 bolt 4g63's after a track day hehe, brings back memories =) Good luck on the build, don't give up!
Stew
27
Jan 22, 2012 09:42 AM
Kahuna_will
Apr 14, 2011 05:53 PM
Invision Evo
Apr 28, 2008 03:02 PM
evo jason
Mar 13, 2006 10:12 AM
95GSXtoEVO8
May 21, 2005 08:38 AM
