20 psi in neutral
Old May 16, 2006 | 01:25 PM
frycztech's Avatar
20 psi in neutral
when i rev my moter when the car is in neutral what could be causing it to boost that high with no load on?
Old May 16, 2006 | 01:29 PM
bluebanana23's Avatar
there was a thread on this but I can't recall what was the culprit.
Old May 16, 2006 | 01:30 PM
Kronik's Avatar
Have you by chance been splicing anything on your harness? I had a friend that accidentally cut his 02 wire to the ecu which caused all types of problems -- including the one you are seeing.
there was a thread on this but I can't recall what was the culprit. A search should tell you.
Old May 16, 2006 | 03:10 PM
frycztech's Avatar
i tryed doing a search couldnt really find anything i sont know if mabe i wasnt wording it right or something. no nothing is spliced in to the harness but i do have a utec as well as some other mods
Old May 16, 2006 | 04:02 PM
Nad1370's Avatar
Is your boost gauge electronic ? Where did you get vaccum source ?
Your gauge might be playing tricks on you.
Old May 16, 2006 | 04:21 PM
dubbleugly01's Avatar
nothing would cause actual boost that high under the conditions you describe. It's a faulty reading for sure.
Old May 16, 2006 | 05:01 PM
frycztech's Avatar
no the gauge is a carbon fiber autometer i got the line of the intake mainfold its telling me iam boosting my full boost and i dont know what it could be
Old May 16, 2006 | 06:44 PM
Nad1370's Avatar
Try a diff. gauge just to eliminate the possibilty of a faulty one.
