just did compression test
Old May 20, 2006 | 09:15 AM
bluebyu36's Avatar
just did compression test on my o3 evo what do you think?
175,175,175,150
Old May 20, 2006 | 09:18 AM
ExViTermini's Avatar
175,175,175,150
I think you need to do it again, that last number is a little scary.
Old May 20, 2006 | 10:12 AM
MalibuJack's Avatar
Yah If I recall thats even (much) lower than the last time you PM'ed me with the value.. Try it again..
Old Jun 21, 2006 | 09:42 AM
okevolutionVIII's Avatar
At 49,850 miles, mine was 163,155,154,154. Thats not good is it?
Old Jun 21, 2006 | 11:27 AM
althemean's Avatar
its showing signs of wearing out with those low numbers.
Old Jun 21, 2006 | 11:44 AM
elhalisf's Avatar
its really hard to find a cheap $30 compression tester that reads good. as long as the comp. numbers read consistant, then your good
mine reads 160, 155, 155, 155. even when i added oil, it didn't change.
Old Jun 21, 2006 | 11:51 AM
BigBADGSX's Avatar
I need to test mine sometime soon... great reminder.
Old Jun 21, 2006 | 12:00 PM
Ninj0x's Avatar
Did you use my How-To? I hope some one got some use out of it. https://www.evolutionm.net/forums/sh...d.php?t=154364
Old Jun 24, 2006 | 12:04 PM
hel_if_ino's Avatar
Here are some numbers from an evo that I am troubleshooting for a friend... let me know what you think.
167, 170, 169, 0 psi
I havent added the oil yet to see if pressure goes up, but I just wanted to ge those numbers out there for input.
Old Jun 24, 2006 | 12:08 PM
cgeist1's Avatar
comp test
if the engine shows 0 psi will will not come back up and if it does it will be very low. he either burnt a compression ring/scored cyl wall, or bent some valves in that cyl
Chris
Old Jun 24, 2006 | 12:21 PM
Evotech8's Avatar
Planning to do this soon.
How long do you need to crank the engine over to get a accurate reading? 2-3 seconds?
Old Jun 24, 2006 | 12:22 PM
hel_if_ino's Avatar
What would be the correct path in determining which of those it could be, I would imagine taking off the valve cover and inspecting the valves, but any input would be helpful, thanks. BTW, after oil add it remained at 0psi, which is what I figured it would do but wanted to complete the test.
Old Jun 24, 2006 | 12:26 PM
hel_if_ino's Avatar
Seems that after 4 or 5 bumps from the cylinder hitting TDC it would stay the same.
