Boosting 11psi removed MBC
Old May 31, 2006 | 09:27 AM
CtSilver03Evo's Avatar
I removed my MBC and hooked up the factory lines... Car is only boosting 11psi now. VERY ODD! I have 1 vaccum line going from the boost selenoid to the intake, and the other goes from the selenoid to the compressor housing/wastegate actualtor (both on that 1 line). Seem right???
ideas?
Pics of factory setup?
Old May 31, 2006 | 09:31 AM
jedibow's Avatar
Maybe you have the lines switched going out of the solenoid?
Old May 31, 2006 | 09:33 AM
i tried swapping em around.. nothing..
Old May 31, 2006 | 09:37 AM
Rnm's Avatar
Rnm
Are you using the factory lines that it came with or just ordinary vacuum lines? Because you NEED to reuse the factory lines as they contain restrictor pills to achieve those boost levels.
Old May 31, 2006 | 09:38 AM
steevo's Avatar
Are you positive that the restrictor pills are still inside the hoses? Double check
Old May 31, 2006 | 09:39 AM
Assassin's Avatar
Yep, like these guys said, i'm willing to bet you're not using the stock hoses huh?
I ran into that same problem a while back.
Old May 31, 2006 | 09:41 AM
This is good information. I honestly had no idea there were "restrictor pills" in the lines. I am useing mostly facotry line except the line that was on the Compressor housing broke on me taking it off, it was fried on basically. I am now using a small aftermarket line for that, and the rest is factory.
Old May 31, 2006 | 09:46 AM
rcheung's Avatar
Your basically running on wastegate boost if you dont have the lines with the pills. Which is why you are boosting so low.
Old May 31, 2006 | 09:49 AM
what do these pills look like? I don't see how I could have lost em.
Old May 31, 2006 | 09:59 AM
steevo's Avatar
Pinch the hose down the line and feel for a small round pill. If you don't have them, you can order the whole set from http://www.mitsubishiparts.net for like $20 bucks or so.
Old May 31, 2006 | 10:00 AM
Thank you.
Old May 31, 2006 | 10:23 AM
Warrtalon's Avatar
It's as simple as you not reusing the stock line going to the compressor nipple. Without it, your boost won't work, and there's no use trying to find any pills. YOu have to get the whole set new from the site listed above for $14.55.
Old May 31, 2006 | 12:19 PM
feldguy's Avatar
Old school, I meant to copy Warrtalon's post NOT yours bro.
I apologize, it was directed as HIM not you.
Old May 31, 2006 | 12:21 PM
oldscholevo's Avatar
lol
ok..cool, I was like what the ????
Old May 31, 2006 | 12:23 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
to be honest i was really confused with your post when you said those things, lol. I'm just thinkin to myself, what the hell, the guy agrees with him and he chews him out for it .
bottom line is this forum needs more love.
