disconnecting speedometer cable?
Old May 31, 2006 | 10:21 PM
sonicnofadz's Avatar
I know this is a super dumb question, but how do you disconnect the speedometer cable from the speedometer sensor (on the backside of the tranny near the firewall)? Its kind of hard to get a good look at the plastic clip that is holding it, it almost seems like it is being held on by a metal clip (like the injectors) but I am not sure...anyone have any suggestions?
Old May 31, 2006 | 10:34 PM
CtSilver03Evo's Avatar
I actually had to replace my speed sensor.. its a ***** to do it without breaking that clip. Good luck. I had to get a "nifty" ratchet behind the Trans mount and losen a bolt. There is a bolt that extends only a couple mm over the top of the speed sensor. You have to back it out. Sucks..
Old May 31, 2006 | 10:58 PM
I don't need to remove the entire sensor from the transmission, I just need to disconnect the cable connected to the sensor. Do you remember what size the bolt is that holds in the sensor? 8mm?
Old May 31, 2006 | 11:09 PM
Hotshot940's Avatar
you just push that metal clip in and pull up on the sensor and it'll come off
Old Jun 1, 2006 | 11:20 AM
For those trying to find this sensor, here is a diagram:
Old Jun 1, 2006 | 12:45 PM
sirloin1219's Avatar
now why would you want to do that? i know on the older cars if you do that it will not keep track of your milage..but on the newer ones is it still the same theory?
Old Jun 1, 2006 | 01:26 PM
My speedometer does not work...I think the cable is damaged, hopefully the sensor is still OK...
Old Jun 1, 2006 | 08:04 PM
replace the sensor to be safe... its not too pricey. I did the gear, the sensor and the harness piece.
It does keep track of the milege. Just the same.
Also, as far as just removing the metal clip, u can prolly do that.. however, you might break some of the plastic off the connector on the Trans bolt. I believe the bolt size was big, like 16-17mm... It's a total ***** to get at too.
Old Jun 5, 2006 | 07:16 AM
Do any of you guys know the part # for the little section of wiring harness that connects to the reverse light switch and the speedometer on the tranny (it detaches from the rest of the wiring harness)? The dealership cannot find this part! Argh.
KentStateTsi
Apr 19, 2017 11:37 AM
Mfell
Jan 30, 2016 07:22 PM
scorpionx13
Lancer Troubleshooting
Jan 6, 2011 09:21 PM
reldas
Jun 27, 2009 02:26 PM
Tek3Evo
Apr 29, 2008 03:22 PM
