Yay. Another speedometer issue thread
Old Apr 18, 2017 | 12:30 PM
KentStateTsi's Avatar
Veteran: Army
Have not found an issue similar to mine. My speedometer only works when pressing the gas. It is accurate when working and I have changed the sensor with a known working one. Same issue with both sensors. I have taken the harness out and cleaned it. No arcing on the terminals like I've seen.
Old Apr 18, 2017 | 02:33 PM
Veteran: Army
Guess I could add some info. 2003 base evo 8. V7 9417 Rom on SD. ABS has been deleted. Code is P0500 vehicle speed signal not present. I feel like it has something to do with the +5v to the sensor. This comes from the ecu correct? I'm not aware of any other power source for sensors.
Old Apr 18, 2017 | 02:43 PM
barneyb's Avatar
Just saying - during acceleration the engine moves on it's mounts. For a test you could jumper the single wire to inside the cabin.
Old Apr 18, 2017 | 02:51 PM
Veteran: Army
I have thought about doinng that. It works at cruise where I have slight pressure on the acceletaror so the engine shouldnt be moving. And I have a solid front roll stop with the other three mounts being the stiff avids.
Old Apr 18, 2017 | 11:20 PM
RightSaid fred's Avatar
Speed sensor is 12v and nothing to do with ECU.
Apart from the ECU using the input.
Old Apr 19, 2017 | 11:15 AM
Veteran: Army
I worded that wrong. Meant to say the signal to ecu. Fixed my issue. At one point in time there was a magical blue vfd piece of crap that references speed installed in the car. The blk/yel wire for speed signal was put back in the acd/ayc spot on the ecu connector. Odd because 03's didn't have either of those. Removed the pin and put it where it should be and bingo. No more speedo drop outs.
Old Apr 19, 2017 | 11:37 AM
supak1111's Avatar
I just noticed mine on hard acceleration all gauges turn off and on really quickly sometimes. After after tephra 7 upgrade
i64X
May 20, 2009 08:14 PM
Jay8141
Apr 28, 2007 01:48 AM
_EVOlved_
May 22, 2006 04:22 AM
jdub24
For Sale - Part Outs
33
Apr 26, 2006 06:38 AM
hpNo7iQ
12
Feb 16, 2006 08:38 PM
