Need Help - Fuses
Old Jun 8, 2006 | 08:32 AM
bigric09's Avatar
there is a guide in the how to section on this forum on where to install the wire... follow it, it works. if you get confused after you read that, then ask !! i followed it and it works great. The line you tapped into on your dimmer switch isnt going to make the gauge dim with the dimmer, its just for a supplied 12vdc that comes on when the lights are turned on... it should have been the farthest wire to the right. Just read the install instructions
Old Jun 8, 2006 | 08:35 AM
EvoDan2004's Avatar
i had it there not to dim the gauge. it was there just to light it. i killed the switch when i tuched the 4 wires togeather. so im re wiring it and geting newdimmer swtch. il look again but i dident see a how to.
Old Jun 8, 2006 | 08:40 AM
bigric09's Avatar
https://www.evolutionm.net/forums/sh...+gauge+install
conveniently enough i went to the how to section, searched for boost gauge install and this is one of many write ups.
Old Jun 8, 2006 | 08:41 AM
EvoDan2004's Avatar
i typed in how to install boost gauge. anyuway thanks alot man.
Old Jun 8, 2006 | 08:44 AM
EvoDan2004's Avatar
ok no. not good. thats what i used to install me gauge. lol. what i need now is to know where to tap my white wire (positive) to other then what he shows. i cant put mine there no more. like i saide above. lol
Old Jun 8, 2006 | 10:11 AM
EvoDan2004's Avatar
bump
Old Jun 8, 2006 | 10:17 AM
hotrod2448's Avatar
Get an add a circuit and pull power out of the cruise control circuit in the fuse panel. It is constant power from the acc. position through start and the Evo doesn't have cruise so it is not being used for anything. That way your boost gauge doesn't start recalibrating as you are cranking the engine.
Old Jun 8, 2006 | 07:34 PM
bigric09's Avatar
if its constant, it wont be how it is suppose to... its hooked to the lights because when you turn them on at night, the gauge lights up. you need to tap into your actual parking light, or tap into the instrument cluster lighting... that may be best. just dont screw it up this time
Old Jun 9, 2006 | 06:41 AM
hotrod2448's Avatar
Is he looking for gauge power or Gauge light power?
The description I gave is for gauge power onan electric gauge. I thought that was what he was looking for. You are correct that hook up would not be correct for lights.
Old Jun 9, 2006 | 07:49 AM
ohio-evo's Avatar
There is a how to on guage installs. I do not have the link but you can tag all wires needed for power and dimming at the cig lighter. That is where i taged mine and it works great. Good luck.
Old Jun 9, 2006 | 07:51 AM
EvoDan2004's Avatar
its all done. but thanks
