Need Help - Fuses
Old Jun 6, 2006 | 02:26 PM
EvoDan2004's Avatar
Need Help - Fuses
UPDATED UPDATED
ok where is a good spot for the pos wire from the boost gauge to go. i had it at the dimmer switch. no good no more. lol. now where.
Old Jun 6, 2006 | 02:34 PM
EvoDan2004's Avatar
anyone??
Old Jun 6, 2006 | 02:47 PM
EvoDan2004's Avatar
?????????? any idea's
Old Jun 6, 2006 | 02:54 PM
Ultimate CC's Avatar
check all your fuses under the panel on the drivers side and also in your engine bay, just start pulling them out one by one, there are diagrams attached to the covers, look on there for the ones that would seem most likely...
Old Jun 6, 2006 | 03:12 PM
EvoDan2004's Avatar
under my dash there was no cover. hum. odd. i didetnwant to pull 40+ fuses but i gess im going to have too.
Old Jun 6, 2006 | 03:48 PM
on the drivers side, reach down with left hand, there should be a place where fuses are...
Old Jun 6, 2006 | 03:59 PM
EvoDan2004's Avatar
yes i no that part. i just pulled all thr fuses but none sems bad. hum.
Old Jun 6, 2006 | 04:06 PM
EvoDan2004's Avatar
ok i just tested the gauge. it is good. now wtf with the fuse. witch one is it. i pulled them all. they all seem good.
Old Jun 6, 2006 | 04:16 PM
EvoDan2004's Avatar
ok does this sound right. with the lights off the gauge cluster is bright. when the lights are on the gauge cluster gets dimmer. . but the dimmer switch doest seem to dim the gauges as much as it used to.
note. my pos wire for the defi boost is conected to the dimmer. boost gauge wont light up. but dimmer switch works. i tested the gauge and it works. ?????????????????????????????????????????????????? ????????????????
Old Jun 6, 2006 | 04:19 PM
bigric09's Avatar
you have a fuse listing in your owners manual...i know its strange to think to look there but amazingly enough, its there. try it out... see if it works for ya
Old Jun 6, 2006 | 04:35 PM
EvoDan2004's Avatar
im looking now
Old Jun 6, 2006 | 05:19 PM
EvoDan2004's Avatar
bump foir update
Old Jun 8, 2006 | 07:36 AM
EvoDan2004's Avatar
bump for updated info. thanks
Old Jun 8, 2006 | 07:43 AM
EvoDan2004's Avatar
anyone?
Old Jun 8, 2006 | 08:28 AM
EvoDan2004's Avatar
bump.
