Dealer Installed Brake Ducting?
Old Apr 20, 2003 | 05:07 PM
Raptor303's Avatar
I've noticed that brake ducting is listed in the dealer installed options. I've tried a search, but I've found little as to what it actually is. I was under the impression that the Evo came with some sort of ducting standard. What's the difference between the two? How do I tell if the dealer actually installed it or if they are BSing me?
Thanks!
-Mike
Old Apr 20, 2003 | 06:08 PM
jfh's Avatar
jfh
The accessory (dealer installed) brake ducting consists of a n abs plastic diverter that mounts to each of the lower A-arms to further direct the air to the brakes. They are not present in the photo, but you can see the A-arms that the diverters mount to. They are really more of air diverters than they are ducting in the traditional sense. If you have them you will see the additional pieces under your car that are not present in the photo.
The front, aerodynamic undertray in the photo of an EVO VII effectively manages airflow under the front of the vehicle and directs incoming air toward the brakes, transmission, and differentials while also reducing lift and drag.
Old Apr 20, 2003 | 10:41 PM
Celm's Avatar
i think it also includes this piece.I thinks its bull crap how is trying to suck every last penny out of you EVO owner,When these parts are OEM on the JDM EVO`s
Old Apr 20, 2003 | 10:42 PM
Raptor303's Avatar
Doesn't look like that bit of plastic is worth $200. I was expecting something cooler, like the sweet ducting they have on all the LMP cars. Oh well.
Old Apr 21, 2003 | 06:30 PM
jfh's Avatar
jfh
That little piece of black plastic in Celm's posted image is the "brake cooling air guide" listed as an optional accessory.
Old Apr 21, 2003 | 06:49 PM
jfh's Avatar
jfh
To clarify exactly what I am referring to:
Old Apr 21, 2003 | 08:08 PM
Celm's Avatar
200 Bucks.You can tell them where to shove that figure.i bet you can make that piece out of plexy glass or even carbon fiber
