Q- BR magnaflow exhaust
Old Jun 25, 2006 | 09:32 PM
forbidden color's Avatar
Does the BR Magnaflow down pipe use a gasket or does it just fit in without the doughnut gasket?
thanks for the quick answer.
I know rest of the pipe uses 2 clamps and 1 gasket where the dp meets the rest of the exhaust.
Also, did all of you use stock spring bolts or just regular bolt on the downpipe?
Old Jun 25, 2006 | 10:06 PM
Silk's Avatar
Just fits in without the donut gasket.
Old Jun 26, 2006 | 10:19 AM
res04's Avatar
and leaks because of it.
Old Jun 26, 2006 | 10:22 AM
res04's Avatar
spring bolts are a must to allow movement of the exhaust due to engine movement. I believe some DP's with flex joints are the exception to this rule but dont quote me on that.
Old Jun 26, 2006 | 10:28 AM
Aux.'s Avatar
If you follow the directions it says to remove the spring bolt and use the ones that they (Buschur) supplies.
As for the donut gasket.... it comesoffif you want the DP to connect. Oh and no i didn't use gaskets. If you have any leaks near the slip fit clamps then use a impact wrench...it will work, trust me.
David Buschur
458
Aug 20, 2015 06:41 AM
SamTrippyMan
Aug 17, 2015 10:52 AM
EvoVIII :D
17
Jun 29, 2014 12:18 PM
gomezgoku
Nov 2, 2011 02:23 PM
kozmic27
Jun 28, 2009 11:38 PM
