got new evo now problems
Old Jun 29, 2006 | 04:41 PM
superflyevo's Avatar
so i got the 03 ww evo last weekend i was so happy to be driving a evo again
so anyways the problem is when i turn the key off the freekin car stays running
i think it is the tumbler switch
what do you guys think
Old Jun 29, 2006 | 04:42 PM
yellowmars's Avatar
does it have a turbo timer?
Old Jun 29, 2006 | 04:53 PM
Tom Selleck's Avatar
Yea, see if it turns off after 30 seconds, 1 minute, 2 minutes, etc. Sounds like a turbo timer.
Old Jun 29, 2006 | 04:54 PM
KartaRailed's Avatar
theres probibly an alarm with a turbo timer built in, check with whoever you got it from .
Old Jun 29, 2006 | 04:57 PM
Dr. SS's Avatar
its "dieseling" make sure its not a carbureted evo...
Old Jun 29, 2006 | 05:02 PM
lol
Old Jun 29, 2006 | 05:03 PM
there is no turbo timer
Old Jun 29, 2006 | 05:09 PM
khmerstyle's Avatar
Originally Posted by superflyevo
lol
hahahaah +1
Old Jun 29, 2006 | 05:12 PM
rcheung's Avatar
If it stays on how long does it take to turn it off? Do you have to take the key in and out to turn it off or does it turn off by itself? Is the ignition harness under the streering column to the right plugged into anything?
Old Jun 29, 2006 | 05:29 PM
ok fokes i jus talked to the kid that i bought it off of
it has a turbo timer
he said he told me but it was 3:30 in the morning and i jus got done driving 7 hrs
when i picked it up
soo my bad
Old Jun 29, 2006 | 05:32 PM
EvO6-RS2's Avatar
Hahahahaha....that's how it goes....LOL
Old Jun 29, 2006 | 07:35 PM
el producto's Avatar
If the turbo timer was hooked up correctly you should be able to pull ebrake up then take out key then release the ebrake and your turbo timer should shut your car off, this is an anti theft feature.
Old Jun 29, 2006 | 07:52 PM
rice_rocket88's Avatar
If you can find that Turbo timer, most have an "off" button that will turn it off permanently. Others you just hold a button down and it will shut off just for that moment.
Generally the lowest time is like 30 secs if it's on, the max like 10 minutes.
The Ebrake thing should work as mentioned. It's a fail safe in case you have the TT running and someone jumps into your car and tries to take off.
If not, trace back for a grey wire from the unit and that should go to the Ebrake wire. (a ground wire).
Old Jun 29, 2006 | 08:53 PM
SlyEvo's Avatar
so where did he hide that turbotimer? =p
Old Jun 29, 2006 | 08:56 PM
GPTourer's Avatar
Unbelievable.
