WOT shifting = thump noise
anyone else? When im WOT shifting, most times i get this "thump" noice, sounds really aggressive, as if my car is going to break, maybe im just shifting too fast or letting the clutch out too fast? Anyone elsE?????
i get that too ....is it coming from under you ? the center of the car?
You are letting out the clutch too fast, your rear diff is creating that noise. I was doing that same thing when I got into the evo, just practice to shift quick, yet a bit more gentle. After a while you will get it.
I've done that once in a while when shifting really fast. You're just letting the clutch out a little fast. I dont think you should worry about it too much unless your constantly doing it. Just learn to shift a little smoother
Originally Posted by Danny23
its called banging gears!
yea, pretty much, I bang gear through gear, i guess AWD is different than my RWD g35 -.- but I don't understand why? -.-
Originally Posted by hondafan
it's because your rear diff has rubber bushings that allow it to move under extreme load. i think it's energy suspension(if not, prothane)makes polyurethane replacements for them that should eliminate the thump.
oh nice thanks for the info, so if i get the aftermarket bushings, and that eliminates movemant im guessing? is that bad for the rear diff????
Originally Posted by Viciouslord
i just got my bushings... we'll see how it works....
Simon
what if you are trying to get a good 1/4 mile time, you should still feather the clutch? If you are racing I can't imagine that you would want to release the clutch slowly?? Am I wrong??
