wheel bearing issue...anyone else?
Old Jul 7, 2006 | 05:07 PM
EiEVO's Avatar
So i figured out what the noise i was hearing from the rear of the car at higher speeds. The drivers rear wheel bearing has some play in it and is making a lot of noise... I can actually feel some play so its definatly bad. I do this type of work for a living so it wont be a issue do get the job done. I just figured out that only mitsubishi offers a new bearing. I would like to know if anyone else has had any of their wheel bearings go bad?
Old Jul 7, 2006 | 06:16 PM
EiEVO's Avatar
bump.....
Old Jul 7, 2006 | 06:48 PM
stryderlis's Avatar
Did you slide into a curb or something? I know that my bearing went bad when I slid into a curb. Mitsubishi doesn't sell just the bearing, you have to buy the whole hub.
Old Jul 7, 2006 | 06:53 PM
BigBADGSX's Avatar
wow I wonder how much its going to be to pick up the whole hub.... that might hurt the pocket.
then again to the guy above are you 100% about your comment?
Old Jul 7, 2006 | 06:54 PM
hondafan's Avatar
how much does that run?
Old Jul 7, 2006 | 07:04 PM
stryderlis's Avatar
It was like 170 or something like that. I'm not sure what the exact number was.
Old Jul 7, 2006 | 07:05 PM
hondafan's Avatar
not quite as much of a hit as i'd expect from mitsu.
Old Jul 7, 2006 | 08:34 PM
EiEVO's Avatar
well i have owned the car for about 40 days and i have never hit anything. All the wheels look good and carfax shows no wrecks. The hub seems to be good and the tires wear good so i would have to say the hub is good. as for its not bet as along with the rest of the suspension. Yea i figured as much when i was unable to get just the bearing from my supplier. I got a price from mitsu and it was $110.00 we will se if its the correct hub/bearing assembly and if the problem goes away.
Old Jul 7, 2006 | 10:27 PM
timzcat's Avatar
Easy to tell if it's the bearing.
When it is making the noise steer right and steer left.
One way makes it louder the other it will all but go away.
It's been so long but it should be whatever direction of steer is the opposite bearing.
So turning left would make it louder so it's the right bearing and vice versa.
Old Jul 7, 2006 | 10:56 PM
EiEVO's Avatar
i know what one it is. I can feel the play in the wheel when the cars on the lift. and its the rear wheel so it wouldnt be when turning. Its kinda hard to hear with a aftermarket exhaust. But really noticeable at higher speeds.
Old Jul 7, 2006 | 11:01 PM
timzcat's Avatar
The turning is to increase or decrease the load on the wheels. Nevermind you didn't get the point of my post.
Old Jul 7, 2006 | 11:06 PM
EiEVO's Avatar
I understand what you meant. It would be more noticable if it were one of the front bearings. And what you mean makes sense just i would have to drive it like it was a NASCAR to actually hear it. All i was asking from everyone is if they have had any issues with wheel bearings on their evos. Cause i havent seen.
Thanks for the input tho.
Old Jul 8, 2006 | 09:39 AM
hondafan's Avatar
actually, i think it was sport compact car or another mag that had an 03 evo for a 50,000 mile long term test and the only things that broke were the intercooler sprayer and a wheel bearing.
Old Jul 15, 2006 | 05:29 AM
EiEVO's Avatar
anyone know where i can get the oem part number for the LR wheel bearing. I believe the Left and Right are the same...But not sure.
Old Jul 15, 2006 | 06:23 AM
texas911's Avatar
Could be you just need some new tires. Bad tires sometimes sound like a bad bearing.
