Boost Leaking
Old Jul 10, 2006 | 06:09 PM
KartaRailed's Avatar
Boost Leaking
Newbie question asked by a newbie. How can i do a boost pressure test. I think i might be leaking a little bit, under part throttle, before you hear the turbo spool up, i can hear a little whining noise, at first i thought it was the turbo but it has a different sound to it. Thanks for your time all.
Old Jul 10, 2006 | 06:14 PM
hondafan's Avatar
newbie told to search under boost leak test by evolving member. there are several threads on this subject. i suggest everyone that hasn't done a test do one because even when you don't think you have a leak, sometimes you do. i just did my first test and found a torn vacuum line and some loose clamps here and there. needless to say, the car runs much better now.
Old Jul 10, 2006 | 06:17 PM
BaLListic_EVO's Avatar
yeah u can make a pressure tester out of a couple parts avaliable @ lowes or home depot.... i found a rubber pipe reducer and plug from the plumbing section worked great then i drilled a hole in the plug and popped a valve stem into it...
Old Jul 10, 2006 | 06:21 PM
hondafan's Avatar
sent you a PM
Old Jul 10, 2006 | 06:39 PM
Warrtalon's Avatar
http://vfaq.com/mods/ICtester.html
I wouldn't be surprised if you had a boost leak, if not several, but I WOULD be surprised if a boost leak had anything to do with a part-throttle, pre-boost whining noise. A boost leak doesn't whine.
Old Jul 10, 2006 | 06:44 PM
cfdfireman1's Avatar
visual
A little soapy water in a spray bottle makes it a lot easier to find the smaller leaks.
Old Jul 10, 2006 | 06:47 PM
Warrtalon's Avatar
Soapy water in a spray bottle is a must.
