Spike 26psi on 91 octane
Anyone here spiking 25-26 psi on 91 octane?? All I have is a TBE, drop in, and flash. I dont have a MBC, but my boost keeps shooting up to 25-26psi especially in 2nd and 3rd gear. For some reason, it just started happening last week or so even though I've been tuned for like a month. I have'nt changed anything on the car since so I'm wondering if something went wrong and caused this?
Originally Posted by RenoEvo
He was tuned with that exhaust so that shouldnt be the issue. I still dont know why you haven't contacted Shiv. This worries me as I'm planning on going down there soon.
Originally Posted by Rnm
Isn't that the boost level where Shiv tunes anyways? I've seen some threads in which he has IX's spiking to 24psi on 91 octane...
Originally Posted by Evotech8
Wow...doesn't leave much margin of safety spiking so high (25-26psi) on **** 91oct. even with a IX.
What's your AFR?
What's your AFR?
If you look around in some threads you'll that a lot of tuners have been running more boost on the IX due to the revised head design which is less prone to knock and detonation. 23-24psi is the norm with proper tuning. The tunes for 91 oct. run just about as much boost but less timing. If you're seeing 2-3psi of spike after being tuned I would definitely make it a priority to get a hold of Shiv and see whats up. You're motor might be skatin on thin ice so dont get too crazy until you figure everything out.
If it spikes than you need to port your wastegate. A manual boost controler wont help if your wastegate cant expell exhaust gasses quickly enough. STI guys all have to do the same thing after a free flowing TBE. SO did i
