AC Rattling
Old Jul 18, 2006 | 12:00 PM
~EVILEVO~'s Avatar
Whats A/C This is Arizona what do you need A/C for? 475 works great
Old Jul 18, 2006 | 12:05 PM
turbotekray's Avatar
its over 100 degrees here , ac or
Old Jul 18, 2006 | 12:27 PM
IMR-TIM's Avatar
Originally Posted by PA-silver03evo
Yep, mine did it since day 1. I dont think theres anything you can really do about it.
+1...I was told by my dealer that it was normal. I test drove another Evo that same day, and it did the same as my car. I have been living with my annoying rattle since day one as well. Even under factory warranty they wouldn;t replace anything. "No faulty parts found."
03 VIII w/28k...air conditioning is still ice cold...clutch still workin great
Old Jul 18, 2006 | 12:43 PM
ShtrMcGavin's Avatar
i was pretty sure it was normal I was just hoping someone had found a way to make it stop. O well its only about 108 today so i think I can live with a little rattle
Old Jul 18, 2006 | 01:52 PM
IMR-TIM's Avatar
....I can;t wait to hear mine rattle. That means I'm driving home from work in the AC ....it's 106 in the shop here today, hot enough to breed sheep
Old Jul 18, 2006 | 04:38 PM
sonicnofadz's Avatar
Not only does every Evo do this, but just about every DSM too. Many other domestic and import cars as well. Boo hoo. If you have an aftermarket clutch alot of times you will get "clutch chatter" where the springs on the disc (or other parts) make noise. You could always drop the tranny, buy a new TOB, grease everything up properly, and bolt everything back together, but even this is still not a garauntee that it will go away. If it is REALLY loud I would be concerned (could possible destroy your flywheel, disc, pressure plate, or worse).
Old Jul 18, 2006 | 05:07 PM
GPTourer's Avatar
My Evo does it, my GS-T does not. Maybe it is just an AWD thing, but I don't remember if my GSX did or not, but there were so many other noises it made I might not have noticed.
Old Jul 18, 2006 | 05:51 PM
It really is just a crap shoot. If you did not properly grease on the throw out bearing or the fingers on the pressure plate, you will get noise. Sometimes it is not the throw out bearing, it is the disc itself making the noise.
Old Jul 26, 2006 | 11:53 AM
mshain's Avatar
Lightbulb ac rattle
he said rattle goes away when clutch is pressed. it is the inputshaft bearing.not throw out bearing.the ac makes it louder due to more load on engine. if you listen when ac is off, you can hear rattle; just not as loud. are most of evo members, 16-23 years old. the reason why i ask is that when service dept tells you normal, you accept it. you should hear no noises from transmission on any car. it is not an ac noise; it is a tranny problem. call an independent tranny shop, and they will tell you the same thing. for the last time, tob makes noise when clutch is disengaged; that means when you press clutch to floor, not the other way around, like everyone thinks.
Old Jul 26, 2006 | 01:11 PM
When you press on the clutch pedal and the noise goes away, this usually implies it is the throw out bearing. Since his transmission is at most 3 years old, I doubt the main input shaft bearing is making noise (although this is possible). Throw out bearing noise is very common among all manual transmission cars.
Old Jul 28, 2006 | 07:51 AM
Kurt's Avatar
Thanks for the info. I have the same noise on my Lancer. I thought it was the throw out bearing. So I replace it along with a new clutch and lightweight flywheel. I looked at the stock throw out bearing and it look trashed after 40,000 miles and the stock clutch and flywheel, although worn down a little, were in good shape. I still have the same noise after having everything replaced. Looks like I am taking it back to the shop and have them check the input shaft bearing.
Old Jul 28, 2006 | 09:11 AM
prest0's Avatar
AC noise
I just keep the clutch in or AC off. The noise drives me nuts. Yeah, helpful I know.
Old Jul 28, 2006 | 09:35 AM
Lots of people don't properly lube the throwout bearing and this can lead to premature failure or excess noise.
Old Jul 28, 2006 | 09:47 AM
I installed a TBE the other day and The rattling has stopped almost completely.. much better
Old Jul 28, 2006 | 01:51 PM
GPTourer's Avatar
I have heard this same noise in F-bodies (Camaro and Firebird) C5 Vettes and 350Z's/G35's.
I hear a lot of people say installing a TBE eliminates the noise. How/Why is this? Does it just raise your idle speed a little, counteracting the effect of the A/C?
