AC Rattling
Old Jul 29, 2006 | 10:36 AM
  #31
mshain's Avatar
Red face damaged inputshaft bearing rattle
for the last time , tob makes noise when clutch is pressed. again, he says rattle stops when clutch is pressed. if it was tob rattle would not go away when he disengages clutch. when he starts to engaged clutch the inputshaft bearing is damaged, and is not turning smoothly. this will also cause the inputshaft to be out of specs. in time, the inputshaft will start to rub on the inside of transmission. when this happens, you will start to hear a torque noise it, sounds like a moan, and you will feel the vibration threw the bottom of the car. another guy said ........ all clutch components were replaced, and he still has rattle, no kidding. mitsu will never tell you isb , because they do not want anything to do with removing tranny to replace, adjust , what needs to be done. go to a honest mechanic he will tell you the same thing. you asked how to make it stop, here it is.
SilverNine
Nov 10, 2011 01:11 AM
mufasis
Sep 14, 2010 11:15 AM
bboy_RES
Feb 11, 2009 05:00 PM
kikiboi
11
Jul 20, 2008 03:11 PM
EVIL_EVO_VIII
20
Sep 26, 2007 09:17 AM
