High pressure radiator caps ??
Old Jul 24, 2006 | 01:13 PM
Aux.'s Avatar
Does anyone know the difference between high pressure radiator caps. The have the 1.3 and the 1.8 and i am trying to upgrade but don't know the difference between the two. Anyone know why someone would get the 1.3 instead of the 1.8 ? Anyone with any experiences or bad stories (or even good to share) ?
Old Jul 24, 2006 | 01:16 PM
kekek's Avatar
The higher pressure caps raise the boiling point (temperature) of the cooling fluid. Only potential downfall is bursting an old hose, not something I would worry about with a newer car. Also a pretty useless mod unless the car will see track time.
Old Jul 24, 2006 | 02:37 PM
Steve_P's Avatar
you can balloon a radiator with a high pressure cap- i've seen it done with a ~20 psi cap. No way I'd use a 1.8. A high pressure cap is just a band aid for the problem- if you even have one. If you are not overheating don't use a cap with a higher rating- higher pressure should not be considered a necessary "upgrade". With a 14 psi cap and 50/50 mix antifreeze-water the boiling point is ~265F IIRC.
Old Jul 24, 2006 | 05:31 PM
Aux.'s Avatar
Thanks guys i appreciate the input. But another question i have is with increased power you obviously have increased temperatures, at what level does the temps actually start to rise (hp level that is) ?
Mellon Racing
Feb 28, 2011 01:42 PM
AWD 8
Aug 11, 2010 07:23 PM
silex
Apr 10, 2007 09:09 AM
