New launch control builds 20+psi!
Old Aug 3, 2006 | 10:20 PM
  #46
ST's Avatar
ST
Originally Posted by JohnBradley
There is alot of mis-information in this thread this much is true. One thing that isnt mis-info is the ability to raise boost with a flash independent of RPM increase. I did it today. Its not as effective as an actual 2 step box like a DIS2, but its better than nothing (and it costs nothing...win win).
Care to elaborate? I assume this is with ECUFLash?
Old Aug 3, 2006 | 10:25 PM
  #47
JohnBradley's Avatar
Yes it is with ECUflash, and there is a brief synopsis in the ECUflash forum. I have managed to make 14 psi at 5625 with no stutterbox, all off the stock ECU.
Old Jul 3, 2007 | 07:10 PM
  #48
BoostnEvoNaz's Avatar
Please Pm me about this box you purchased.
Old Jul 3, 2007 | 08:33 PM
  #49
Erik@MIL.SPEC's Avatar
Please pm me about your broken TC.
Old Jul 3, 2007 | 08:54 PM
  #50
blkdinan's Avatar
Pm sent. Oh, guess what! I did break my TC....launched the car on a concrete bridge and when the front tires came back to the ground something had to give. Put a helical in and no problems since.
And guess what the guy I raced that day still lost and he is the one that told me the front came up and is also the same person who now has it on his car.
Old Jul 4, 2007 | 04:17 AM
  #51
Mellon Racing's Avatar
cmon man, you didn't pop a wheelie
Old Jul 4, 2007 | 04:25 AM
  #52
EVIL MR's Avatar
I get 17psi if I hold in for 5 sec.
Old Jul 4, 2007 | 04:58 AM
  #53
EVOlution561's Avatar
launching an evo at 20psi is so harsh on the driveline parts. I used to launch mine at about 10-11 at 6k and I got consistent 1.6s with some in the 1.5s
Old Jul 4, 2007 | 07:09 AM
  #54
TTP Engineering's Avatar
You did not lift the front wheels. Sweet dreams, go back to bed.
Old Jul 4, 2007 | 07:15 AM
  #55
EvoDan2004's Avatar
my launch control only mkes 6psi. weak. is it because im on the stock ecu or can it be turn'd up at all. i would like 12ish psi
Old Jul 4, 2007 | 08:34 AM
  #56
chuntington101's Avatar
the like of motec standalones have some very intresting features like anti-lag and launch control. there are two types of launch control i have seen. one is the proper ***** out anti-lag ones and the other is a 2step.
personaly, although a 2step might work for drag racing, it wont help anywhere else! what a 2step does is when you are stationary and in gear it will set a fake rev limit that you can normally adjust. once you hit that limit it basicall CUTS the ignition. this puts some load on the engine and helps make boost!
now a proper system like the rally gusy use is diffrent! they run anti-lag, with launch control. anti-lag work by RETARDING the timing not cutting it! this means you still load the engine but also the turbo is hit by the still burn exhaust gasses. basically like hitting the turbo with a bat! lol
this give really good boost on the line.
also you cna use the antilag when you come off the throttle bettween shifts to keep the turbo spooled.
hope this helps
Chris.
Old Jul 4, 2007 | 08:42 AM
  #57
hope this helps
Chris.
You are incorrect on all accounts.
There is no "fake rev limit".
A 2 step from the ECU is a fuel cut and not an ignition cut.
It does not put any load on the engine.
Hitting a turbo with a bat would not make it spool up either.
Old Jul 4, 2007 | 08:48 AM
  #58
Evoryder's Avatar
lol @ scott x2 ...
Old Jul 4, 2007 | 09:02 AM
  #59
EVOlutionary's Avatar
Many brain cells died after reading this retarded thread. Thank you for making me stupider . . . .
I bet if your buddy with the SRT4 got one of these boxes he could pop a wheelie while launching too!!
Old Jul 4, 2007 | 09:18 AM
  #60
oneguy's Avatar
I believe you meant "counts"
