Chipped Throttle Body? What?
Pretty strange... I did a boost leak test and found 4 big leaks. One was at the TB. I took off the UICP and found this:
Now I am clueless as to how this happened but the funny thing was, the boost leak actually turned out to be the TB shaft seals. So basically my throttle body is just a big mess right now! Leaking and chipped.
Anyone have any ideas how a throttle body chips like that? My clamp was set all the way back not even near the edge. Its only been taken on/off once when the clutch went on last month. Other than that, never. I actually have the peice of the TB that came off, its very small as you can see, it was just sitting snug on there.
Im in search for a 2005 OEM TB now!
I am the original owner of the car.
Didnt even have a T-bolt on there. Yes the shaft seals are leaking (which is another problem in itself). You can buy a new shaft seal. Its $11 from MachV. The DSM ones fit the EVO.
Yeah I know. The little peice of the TB was just sitting there, I kinda just took it off. Thank god.
Originally Posted by taenaive
that is weired! maybe you applied T-bolt clamp too tight or something?
and the seal is leaking? how do you fix that? I don't think they sell the seal only.
Originally Posted by 4TUN8
Atleast it didnt get sucked into the intake mani
Originally Posted by RenoEvo
Yeah right.
Unless he gets his girl (avatar) to walk in the dealership wearing assless chaps, nothings gonna happen!
Yeah in all seriousness, do you think theyd warranty anything on my car? Its full bolt on tuned cammed yada yada. Theyd laugh very hard.
Yeah right.
Unless he gets his girl (avatar) to walk in the dealership wearing assless chaps, nothings gonna happen!What kind of UICP are you running? Stock?
Originally Posted by Soon2BEVO
That just made my day
My buddy got major warranty work done and he has everything you do, so its very possible they won't give you problems. A lot of it has to do with your attitude, appearance, and composure. GOOD LUCK, ITS POSSIBLE!
it looks as if it pried apart like someone used a screwdriver to seperate it from the intake mani/hose couplers or something (pic is a little crappy) but damaged it in prying it....
Originally Posted by Brian_H
I don't work for mitsu but I'd honor that warranty. Still waiting for video BTW.
Some dealerships out west are really cool when it comes to modding so I guess it just depends on where you are. My local dealership is cool with all the "basic bolt ons" but not cool with big turbos, alky, etc. If I was you I'd make the car look stock under the hood (intake,mbc,etc.) and put the stock cat back on to be safe. Since you have cams and I'm assuming an aftermarket clutch anything can happen
