Engine question
Old Sep 15, 2006 | 06:28 PM
blakevo8's Avatar
Engine question
my car is untuned with intake and exhaust 1thru 3rd gear feel normal but 4th and 5th feel way to slow. Its obviously not a boost leak because my gauge reads 19. Could there still be a leak in the intake manifold. when i downshift into 4th at about 4,5000rpm and step on it, it sounds like the car should be going faster, it almost feels like a bad head gasket, could this be my clutch, the throw out bearing is making some noise.
Old Sep 15, 2006 | 06:30 PM
ak47po's Avatar
You lose power with an intake on your car without a tune.
Old Sep 15, 2006 | 06:31 PM
BretTheJet26's Avatar
+1, i took my intake off , put the stocker back on and voila instant power
Old Sep 15, 2006 | 06:32 PM
EVOL EDO's Avatar
tune the car, and the car isnt as strong in 4th and 5th because of the longer gearing so it will feel slower. evo is not a top end car without cams and even then it still isnt a top end car.
Old Sep 15, 2006 | 06:33 PM
Tpayne84's Avatar
Please
What kind of intake do you have?
Old Sep 15, 2006 | 06:36 PM
Originally Posted by Tpayne84
Please
i had the Injen intake. but the thing was, i was dynflashed BEFORE i put the intake on.. retarded move on my part, but once i put the injen on i definately noticed a lack of power, it was like night and day.
ak47po's Avatar
You want more power a tune is the most cost effective way to make power.
Old Sep 15, 2006 | 06:39 PM
blakevo8's Avatar
injen- i understand letting in more air untuned will give the car a neg affect but at high rpms it shouldent be that bad. 1st and second gear pull harder especially at higher rpms, but i almost scared now cause i go in 4th and the motor just sounds like its making more power, it feels like im am being held back in 4th and 5th, this happened before any of the mods all of it was done about a month ago. my throw out bearing is starting to make some noise, i think my clutch could just be getting worn and at those high speeds its not grabbing as well i duno
Tpayne84's Avatar
Just adding an intake wont make a night and day difference on losing power. Going from that i would have to say that there is deff something wrong with your car.
I had a intake untuned on my car and i couldnt tell any difference at all.
Old Sep 15, 2006 | 06:42 PM
thats all and good for you, im just telling you my experience
Old Sep 15, 2006 | 06:44 PM
ak47po's Avatar
Intake on Evo with no tune mean's running lean,Bad new's.
Old Sep 15, 2006 | 06:45 PM
yes and since i had my intake on after my my tune mean i was probably running super lean, and retarding timing. just a guess
Old Sep 15, 2006 | 06:47 PM
Tpayne84's Avatar
And im just telling you that, that tiny amount of power that you "gained" back would be unnoticable anyway. Maybe it drove smoother or something like that i would believe. but your acting like you were missing 50whp.
Old Sep 15, 2006 | 06:49 PM
Tpayne84's Avatar
With a intake on no tune you MAF goes crazy and you run RICH not lean.
Old Sep 15, 2006 | 06:57 PM
ak47po's Avatar
I think you have that backward's.
