Car does not idle on its own.
Old Aug 8, 2009 | 02:14 PM
  #31
Boost3dxEvO's Avatar
hmmm.. this is an older thread, but has any one figured this problem out? sounds similar to what is going on with my car.. I even swapped out the IAC with another unit.. still no luck.
Old Aug 8, 2009 | 02:42 PM
  #32
ddubdb3's Avatar
try your mass airflow sensor..disconnect it and start the car and see if it idles
Old Aug 8, 2009 | 07:30 PM
  #33
I disconnected the MAF and the car seems to want to idle better, but the car still dies after I let off the gas.. any suggestions?
Old Aug 8, 2009 | 11:22 PM
  #34
ddubdb3's Avatar
no codes? no boost leaks??
Old Aug 9, 2009 | 10:15 AM
  #35
There are codes after the MAF is unplugged, but I'm assuming they are related to the MAF being unplugged.. the only one that doesn't seem right is the P0183 code for Fuel Tank Temperature circuit high input..
All boost leaks have been checked with a boost leak tester and the car holds 20psi with no issues.. There was a couple of small vacuum leaks at the intake manifold, but they were fixed immediately with no changes.
Old Aug 9, 2009 | 01:17 PM
  #36
aschold's Avatar
Take off the SAFC. The previous owner of my car had one installed and my car liked to do the same thing, just not as bad as you are describing. I removed the SAFC and now it never happens.
Old Aug 9, 2009 | 01:25 PM
  #37
This thread is from 2006.. It was brought back from the dead since I'm having a similar issue, I don't have an SAFC though.. those are garbage.
Old Aug 9, 2009 | 02:09 PM
  #38
aschold's Avatar
Oh, my bad, you have the same avatar as the OP hahaha
Old Aug 9, 2009 | 03:48 PM
  #39
No worries man, I really hope I solve this issue soon!
Old Aug 9, 2009 | 06:36 PM
  #40
bump
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
sgambino92
16
Apr 20, 2017 08:23 AM
jennz03
Lancer Troubleshooting
Feb 20, 2017 08:15 PM
Evo47
Dec 10, 2015 09:46 AM
mitsuevo803
12
Jul 9, 2008 09:44 PM
