I think I own the worlds most poorly built EVO
Old Oct 4, 2006 | 06:51 AM
  #46
mjo's Avatar
mjo
Originally Posted by SpyderBite
I'll see if I can do that. Cause the only problems i've had lately seem to be electrical. The tranny has been fine for awhile (minus 4th gear) rotors haven't warped in awhile, axels seemed to be doing ok. I know a lot of the bumps and bruises were probably due to the horrible road conditions we have here.
Oh and I forgot to mention, the dealer did call and the motor did not crank walk. Apparently when I hit a road cone earlier in the week, something got torn up and finally popped off. I have to go in tomorrow to talk to them and get more details on it. But they said they got the motor fired up again.
Is there a way to check the computer chip without having to get a standalone system to see if that'll fix it?
Cause after the dynoflash it ran great even put down some damn good numbers on the dyno compared to my old tune I had.
1st clutch I would admit was my bad probably lol...2nd clutch I had was rated to hold 500hp/tq...I figured it was the shops mistake on a bad install, clutch felt wierd from day one. 3rd clutch lasted about a month, and the one I have in now has been in for about 5 months now. The rotors no one could figure out, they would get replaced and within a few weeks they would be warped.
Have the dealer put in a NEW ECU but since it is moded it might have to be reflashed for the mods. From what I see it points to a problem with the ECU now. The reflash is done in the memory of the ECU and I think that memory is bad.
mjo
Old Oct 4, 2006 | 07:44 AM
  #47
SandSanta's Avatar
Looks like you need to replace the nut behind the wheel.
BURN
No seriously, how the hell do you hit a road cone?
Old Oct 4, 2006 | 07:50 AM
  #48
EVOB23's Avatar
There are times when an owner needs to realize that you play you pay("GEO")
Old Oct 4, 2006 | 11:00 AM
  #49
Turd Squirter's Avatar
Contact a lemon law lawyer and see if you have a case. If you're gonna throw any more money at the car it should go towards litigation. Bad mechanic, bad car, or bad driver...this Evo is having a disproportionate amount of issues.
Old Oct 4, 2006 | 11:14 AM
  #50
hopper's Avatar
Am I the only one that noticed he said it crankwalked? if im not mistaken this is the first case of crankwalk in a evo I call bs
Old Oct 4, 2006 | 12:34 PM
  #51
Ralliart50's Avatar
^to answer your question.
Old Oct 4, 2006 | 01:46 PM
  #52
hopper's Avatar
Ohh ok well he still said that "compression gone bad atleast 3 times" what does that mean?? he replaced the head gasket 3 times? he rebuild the motor atleast 3 times? i still call bs
Old Oct 4, 2006 | 03:03 PM
  #53
Utah-evo's Avatar
I have a black 05 gsr I even got it in the same month as you and have bucsher stage one with a mail in flash. I beat on it every day and have had zero problems even my cluch still grabs like new at 20k miles, I know how to drive though. I think I'll go knock on wood now
Old Oct 4, 2006 | 03:07 PM
  #54
evolusion's Avatar
Is this your first turbo car? or second?
Old Oct 11, 2006 | 06:39 AM
  #55
Kryptonite's Avatar
What happened at the track last night?
Old Oct 11, 2006 | 06:57 AM
  #56
Evoryder's Avatar
Sounds like YOU raped the crap out of your evo...the fan hitting the intercooler...adjust the pipe position?...move on... other junk sounds like straight non lube rape of an evo...
You remind me of Lennie from "Of Mice and Men" .'.. I don't know what happened George, her neck just snapped, I just shook her around a bit'
...sorry, maybe this should be your last evo...sign up with the army...i hear they still drive TANKS!! lol
tsitalon1
47
Jan 15, 2017 07:55 AM
89turbosupra
Oct 17, 2015 03:57 PM
Ian0611
Apr 15, 2013 02:18 PM
Darksun280
Mar 15, 2012 10:37 PM
Frankiago
58
Jul 26, 2011 01:54 PM
