won't boost to 1.4 bar at 3 4 5 gear
Old Oct 3, 2006 | 06:40 AM
oldscholevo's Avatar
ok these few days I was pulling the car hard and notice that at wot at 3 4 5 gear, the car won't boost up to 1.4 bar. but when in 6 gear the boost will go up to 1.4 druning wot. at 3 4 5 gear the boost stays at 1.1 bar. whats going on. did some search, can't find anything close to my problem. please help. check the car everything is good. should i reset the ecu??
Old Oct 3, 2006 | 07:57 AM
3SgteGuru's Avatar
The Boost is supposed to Taper, somayber in the Lower gears your gaining rpm too quick and cant built boost fast enough to reach the Peak boost. Possibly you have a Boost leak. I reach Peak Boost if I pull at like 2700 rpms in 2 at 3000rpms in 3 and 4 and 5 6 pretty much any time i WOT it if i am Above 2500 rpms, car is stock The peak boost of all gears ist at 3500 rpms, but the Rpms i listed are the highest rpms i can start the pull at to reach the peak boost by 3500. My freinds Electric blue evo, He has a TBE and IC piping and Intake w/ a tune from AMS and a Profec b-spec II tuned to 23 psi, pretty much anytime you give it wot it shoots up to 1.4 to 1.6 bar. So its realy different from my Stocker, I did a Second gear Pull with him and he just Took off Like a Rocket.
Old Oct 3, 2006 | 08:05 AM
ok. because if i was on high way the boost will reach 1.4 at 6 gear no matter what rpm range and stays there, but when i pull at 3 4 5 gear the boost will go to 1.4 and drop right down to 1.1, without going to redline.
Old Oct 3, 2006 | 08:06 AM
if i have a leak 6 gear pull won't stay at 1.4.
Old Oct 3, 2006 | 08:33 AM
3SgteGuru's Avatar
IF you Peak then Drop That normal, part of the taper. You do not have a boost leak. Your car is fine.
FYI boost leaks don't change your peak boost level, but change the rate at which you build boost.
Old Oct 3, 2006 | 08:58 AM
ok thanks for the help. I will double check the car, just to make sure everything is good.
Old Oct 3, 2006 | 10:14 AM
3SgteGuru's Avatar
Good luck with your car man, If you going under the hood, just make sure your clamps are tight, you know the Ic pipe problem, use a 10mm socket.
Old Oct 3, 2006 | 11:02 AM
thanks!
Old Feb 4, 2007 | 12:45 PM
AhmadHasib's Avatar
im just writing so i can find this thread in the future
Old Feb 4, 2007 | 12:53 PM
armympjch's Avatar
be careful when racing with the MR. the 4th gear is weak and can brake if your shift hard at high speeds. i guess that it has started happening alot with the MRs, the 4th and 6th gears are weak. i broke mine and now im getting a custom built 5 speed to put into my MR from ShepTrans.com........ just a heads up.
Old Feb 4, 2007 | 12:55 PM
Warrtalon's Avatar
It doesn't typically break from shifting hard. It breaks from the teeth weakening over time due to excessive heat and the breakdown of the fluid. I had over 250 drag runs with 200+ of them including 3-4 powershifts (as hard as you can shift it), but I didn't lose 4th until I was road racing and passing a car in 4th. 4-5-6 are all small and weak with tiny teeth.
I also moved to a custom 5spd from Shep.
Old Feb 5, 2007 | 12:40 AM
Kdash106's Avatar
i was wondering if is normal to hit 1.3 at 1st gear?? i think my car never peaked at 1.5 before. is that normal?
Old Feb 5, 2007 | 01:23 AM
Evo IX MR's Avatar
It sounds normal. I hit 1.4 down to about 1.2 at redline. No aftermarket boost controller.
Old Feb 5, 2007 | 05:27 AM
3SgteGuru's Avatar
^^ is the only one i can Find who has blown apart the MR Tranny. And I drive like a panzy, so i don't have to worry. Go to you tube and find one of his Vids, yeah he drives to win.
