Evo Center Consol Clock
Old Jul 24, 2007 | 07:55 AM
trinydex's Avatar
the radio/temperature cover needs to be removed. then the two screws holding the trim piece in. possibly the gauge cluster bezel if you want to be careful.
Old Jul 24, 2007 | 01:24 PM
GraphiteEVOIX's Avatar
I did it to mine, very easy. It looks alot better once it is done.
Old Jul 24, 2007 | 06:28 PM
ixmrgg's Avatar
How about doing the foglight-switch mod? That way you could get some front illumination without having to light up the HIDs all the time. The fogs would be equivalent to DRLs. Then, as was suggested run your clock from a different source.
Originally Posted by KartaRailed
You could probibly find a different power source to run to the clock, from something that is always on, but if you leave your headlights on all day, the HID's will burn out faster, so I wouldnt recommend it.
Old Jul 24, 2007 | 06:56 PM
92gsxbaltimore's Avatar
I thought the clock was broke at first too bc i was always kept the lights on when i first got it.
Old Jul 24, 2007 | 07:59 PM
cubicleslave's Avatar
Still confused
Does your comment apply to a IX MR? My gauge cluster is way, way below the climate control knobs. It would be cool if somebody could post step-by-step pics. I've removed the radio/temp cover but did not know how to go from there. Thanks again!
Old Jul 24, 2007 | 09:29 PM
urslo4n8's Avatar
Im pretty sure theres a "how-to" on this in that section.
