Installing oil pressure gauge on the car - questions
Originally Posted by sparky
This adapter lets you use one pressure or temp sender. What do you do when you want to run both a temp and pressure sender?
There are two nuts/screws that you remove.
http://bolsen.homeip.net/oilgauge.htm
Originally Posted by SRT Motorsports
A good investment would be the greddy oil filter adapter. It comes with fittings that you dont have to tap into anything for the oil feed
Run's about 50-60 bux
The best option is to go with AMS's remote mounting kit, or just use one of the ports on the side of the block...
[QUOTE=kapolani]Check out this guy's page.
http://bolsen.homeip.net/oilgauge.htm[/QUOTE]
Thanks this link was best.
I personally don't like the sandwich-type oil filter base adapters like the GREDDY unit. I've had a couple bad experiences with similar pieces over the years. Like I said it's just my personal experience.
cij911
139
Mar 19, 2021 04:19 AM
