gauge install
Old Jan 25, 2009 | 09:01 PM
mikeevo21's Avatar
gauge install
does anyone know the step by step instruction how to install an electrical boost gauge, electrical oil temp and digital air fuel ratio from prosport? tnx in advance
Old Jan 25, 2009 | 09:29 PM
KenMasters's Avatar
Did you search the how to's? There are plenty of gauge installs in there.
Old Jan 25, 2009 | 10:00 PM
mikeevo21's Avatar
i did but n luck i need the step by step instruction if u don't mind
Old Jan 25, 2009 | 10:02 PM
sikrsix's Avatar
Keep the air/fuel in the original packaging so you can return it. That gauge is useless.
5 seconds on google:
Boost gauge
Old Jan 25, 2009 | 10:05 PM
detroit pistins's Avatar
i would like to know the step by step as well. hope u find some answers.
Old Jan 25, 2009 | 10:06 PM
Alex Rodriguez's Avatar
Heres for your oil temp gauge
https://www.evolutionm.net/forums/ev...e-senders.html
For your boost gauge , buy a t fitting from the autoparts store and locate your blow off valve, the vacuum line that is on it will be your source for the boost gauge.
Simply cut the line
Install the t-fitting on the hose you just cut
on the 3rd leg of the t-fitting you run that into your gauge
For you air/ratio gauge- its useless unless you have a wideband one(displays numbers) the narrow band ones are the ones with a light spectrum that just dances in the gauge.
If i still remember
one wire gets connected to the o2 sensor, ground, and power
Old Jan 25, 2009 | 10:07 PM
chaotichoax's Avatar
you didn't search very hard
in the how to section there is a detailed install for a defi electronic boost gauge and the oil gauge will use the say install spot for the sensor as a mechanical gauge
I'll even provide the links
agreed
Old Jan 25, 2009 | 10:08 PM
closed...
Old Jan 25, 2009 | 10:19 PM
https://www.evolutionm.net/forums/ev...irections.html
kingcobra10sec
Feb 24, 2017 06:29 PM
W06EMR
Feb 26, 2011 11:07 AM
scumrat
Mar 30, 2008 05:35 PM
blackdemon
25
Jan 13, 2008 10:36 PM
alex_alex
12
Nov 18, 2003 03:52 PM
