need help with electric boost gauge install!
Old Mar 16, 2008 | 12:52 AM
scumrat's Avatar
i just bought an evo 9, i have always owned other turbo cars and installed a few mechanical boost gauges, but never an electric boost gauge. I have a prosport premium electric stepper motor boost gauge to install, can anyone help?? pics would be great! thank you
Old Mar 20, 2008 | 03:05 PM
scumrat's Avatar
anyone??
Old Mar 20, 2008 | 05:08 PM
Celica2EVO's Avatar
ITS A POS! RETURN IT WHILE YOU CAN! I had one of these and the damn thing read 5 psi short! First time I ran with it, I was at wastegate pressure (12 psi) and it was reading 7! Returned it and stayed with my Defi Mechanical! Much better! Its for sale now if you are interested. Thats only because Im upgrading to a 50 psi gauge! If you have any questions about the prosport gauge, just ask me. Ill help you as much as I can. But thats just my warning!
Old Mar 20, 2008 | 08:49 PM
WickedIX's Avatar
I recently installed a prosport electric boost gauge in my IX...Havn't had any problem with it. Have you already started your install?
For the non peak boost gauge, the green wire on the gauge connects to the white wire on the sensor. ground both black wires, and connect the red wires and splice into a power source. If you want the gauge to be amber connect the orange wire (on gauge) to your power source. If you want it white, connect the white wire (on gauge) to the power source. If you want both, connect the white wire to the acc and the orange to your light in the fuse box.
I didn't run the hose all the way into the vehicle. I widend one of the openings on the sensor and connceted it to a bolt on the fire wall. I replaced the T because it was too big, and purchased a better vaccume hose (It comes with cheap aquarium hose) Connected the hose, and ran electrical through a gromet which goes behind the glove box (You will need to remove the glove box and you will see it just above the cabin filter on the right side). Remove the gromet and cut a hole into the center. Run the wire through, then replace the gromet.
I have heard of people connecting the wires to the back of the stereo, seen photos of the wires connected directly to the back of the ignition, and, like what I did, splice into the wires in the fuse box, and to the acc wire behind the steering column.
Sorry I dont have any pics.
Good luck!
Old Mar 20, 2008 | 09:11 PM
Celica2EVO's Avatar
U are a lucky man wicked. Im now a big fan of electric boost gauges, But you cant go wrong with AEM though!
Old Mar 20, 2008 | 09:29 PM
WickedIX's Avatar
I guess I will find out how true the gauge is when I mod and tune my ride. Currently I am stock.
Old Mar 20, 2008 | 10:29 PM
Celica2EVO's Avatar
well if its reading 19.5-20 PSI, yours should be right! Mine wasnt even close! 5 psi!
Old Mar 21, 2008 | 10:56 AM
scumrat's Avatar
thanks for the help should have it installed in no time!!!
Old Mar 21, 2008 | 11:36 PM
WickedIX's Avatar
hows the install going for ya?
Old Mar 30, 2008 | 05:35 PM
AznEvoIX's Avatar
Do it right the first time man. Get some Defi Gauges. =D Like me!
Sorry for the grainy picture. Took it off my cellphone camera.
Install is a ***** however...... (>_<)
W06EMR
Feb 26, 2011 11:07 AM
mikeevo21
Jan 25, 2009 10:19 PM
blackdemon
25
Jan 13, 2008 10:36 PM
lithe
May 20, 2004 01:58 PM
alex_alex
12
Nov 18, 2003 03:52 PM
