installing valentine 1, tapping into left a piller
Old Oct 22, 2006 | 05:32 PM
fyr3's Avatar
hey guys.. i was recently hard-wiring my valentine and i tapped into the red/yellow w/ crimps and the black for my ground and for some reason the unit doesnt turn on. The red wire doesnt seem to power it either.. if i heard right i thought the red/yellow was the sunroof wire, i tried it with the car on and off btw. any ideas? am i retarded? Thanks!
Old Oct 22, 2006 | 08:56 PM
althemean's Avatar
yep. J/K you need to get a multimeter or a test light to make sure you have power and are splicing into the right wires. going by colors is not always your best bet.
Old Oct 23, 2006 | 04:25 AM
AhmadHasib's Avatar
+100000000
simple yet effective
Old Oct 23, 2006 | 04:29 AM
CF-Ninja's Avatar
yah.. tapping into random wires is bad, you'll start blowing fuses if you aren't careful. Or you might put it on something that is always on. Gotta find something wired to an ACC. fuse with the proper ampridge on it.
Old Oct 23, 2006 | 07:46 AM
oldscholevo's Avatar
if you tap into the sunroof wire, it will only work when the sunroof is opening for closing. because the power in not on always. it only supply the power to sunroof when you press the switch. try the cig lighter power if you can.
Old Oct 23, 2006 | 07:58 AM
rice_rocket88's Avatar
Why dont you just run wires a little longer, go down the A-pillar and tap some known good wires.. heck, even the cigarette lighter power!
The A pillar snaps off, and snaps on.. much easier than trying to get to the sunroof wire. Seeing as you're in there, you just need to use the test light to tap for a power that turns on when the car is on. So ground the wire on the frame, turn on the car to the ON position and start tapping away. Once you find a light, then turn the ign to the off to find out if it indeed shuts off when the car is off.
Good luck, it's not that hard, just don't short anything out
Old Oct 23, 2006 | 08:27 AM
fyr3's Avatar
alright, ill get a multimeter, or a test light and try this the right way lol. thanks everybody
Old Oct 23, 2006 | 08:33 AM
Rod Munch's Avatar
I used the V1 hard-wire kit and a fuse adapter, and plugged the adapter into the fuse socket for the rear-window wiper motor, in the fuse box by my left knee. Worked like a charm and no splicing involved ...
Old Oct 23, 2006 | 08:44 AM
hk2ronin's Avatar
i used the ciggarette lighter for power. Just make sure you throw away the vampire clips and take wire strippers to the wires. Strip a little bit, twist together, and electrical tape em. I used the vampire clip @ first but after 6 months the unit would turn on and off @ random. Had to take evrything apart again and do what I just said.
Old Oct 23, 2006 | 08:52 AM
Rod Munch's Avatar
Wow. I hate cutting and stripping OEM wires. The fuse adapter lets you put the car back to stock without touching any of your car's precious insulation or wires. They're maybe $3 at Pep Boys.
Attached Thumbnails installing valentine 1, tapping into left a piller-fuse-adapter.bmp
Old Oct 23, 2006 | 04:10 PM
fyr3's Avatar
those definitely are cool... thanks :P!
Old Oct 23, 2006 | 04:17 PM
Rod Munch's Avatar
My pleasure. I think maybe they're called add-a-fuse.
Old Oct 23, 2006 | 05:02 PM
ShtrMcGavin's Avatar
there is a how-to on this in the how-to section.. i used it to install mine and it worked out well
Flip
Dec 11, 2010 05:03 PM
Gaurav
Nov 25, 2010 07:19 PM
shirk
Lancer Troubleshooting
Sep 1, 2010 09:58 PM
turbolancer02
Lancer How Tos / Installations
Jun 3, 2010 10:19 PM
Midnightkid
11
Jul 30, 2008 04:07 AM
