Winged Warrior III. May 2007 Indy. (import vs USA)
Um, no. I said stock 03/04 Evo GSRs are in group C with +15. You can only add 4 points of mods before you end up in Group B. YOu have +15 on top of C+15, which puts you at B+10. This means you're 10 away from group A. You should read the rules to understand how the classing points work. Basically, it's 20 points per group, which is why C+15 means it only takes 5 mod points to get to B. For every 20 mod points, you go up another class. Your 15 put you 10 points deep into group B, which is 10 points away from A.
There are WICKED Z06 vetts/Saleens etc... all us class "A"guys have to battle against. (That means you too Warrtalon!
ALL those cars are modded also!
) We will whoop them. AWD RULES!
He is in "A", so is a couple 550 HP Z06's, a couple C6 Z06's, a 1083HP viper, etc... I still say they CAN'T HOOK, and we got 'em!! The drag is LOW E/T, I still say we can get to the finish line first.....................will be fun, either way!!
I think they'll still hook well enough to get great ETs, but there's no way the they can find tires that work with all that power for both autox and drag. If they try to put drag radials on the autox course, it's going to be amusing. If they don't use drag radials, they will run 12.0 @ 125.
Boostinjuice, that thing looks like it has 20" rims that weigh 25 lbs each, and the car itself probably weighs 4000lbs or more. I doubt it's been custom built to be sent around an autocross course. It looks more like a show car with lots of straightline WHP, but I could be wrong.
Let me reiterate something: You see the cars I am listing, but those are in class "A"ONLY. there are 6 classes!! Don't get discouraged by the Monsters they have in the wings, us Class "A" cars will slay those dragons, and you slay the dragons in your class for the team!! The Lancers, Ralliarts, hondas, etc... are in their own class, fighting TEAM USA cars in their class. Ie ford Focus SVT's/ and all the other cars which fall in as well. There is MULTI levels of fun, trust me!! And each class has a 1st/2nd/3rd place finisher!! I got LOTS of trophies to get!!
hopefully that bad boy is in class WW-A... if its in B .. im sCREWED
