running extremely rich when getting gas
ok.. i have a walbro 255, aem air to fuel ratio gauge. i got a reflash and tuned by turbotrix. everytime im getting gas, the a/f shows 10 and the car would start boggin. any ideal whats goin on? thanx guys
Carlos
Originally Posted by fromWRXtoEVO
I am not kidding but I heard complaints from Edwin (Evo member) that the actual gas cap open could give you some issues.
Carlos
Carlos
Originally Posted by spdracerut
Did the tune take into account the fuel pump? The walbro can overpower the stock fuel pressure regulator, basically causing more fuel pressure than stock.
I think he means if the gas cap isnt tight enough. It will also through a CEL. Id check to make sure TT accounted for the Walbro. I havent heard anything bad from them on here so i couldnt imagine it being the actual tune. Is it only happen after you fill up the gas tank?
I know it may sound stupid, but make sure your gas cap is tight. It is part of your emissions system and it could throw the ECU off if its not pressurized right. Even if it is tighted it might be a bad gas cap and might not be sealing completely. Not trying to insult your intelligence as im sure you know this, but just putting it out there.
Thats because your supposed to shut your car off when you pump gas.. My car is relativley (sp) stock and if I dont shut my car off when pumping gas, mine will stal out everynow and then.. Just shut it off.. It wont run rich..
yea thats what i have to do now... shut it off everytime i get gas
i am at a loss for words right now. as stated above the gas cap is apart of the emmisons system, and pressurization is crutial. who taught you to fill a car with gas?
