one or two cams
Old Nov 12, 2006 | 10:33 AM
Warrtalon's Avatar
Originally Posted by bizzarro
The intake cam is the mivec cam. Companys have just started to release the intake cams now. So yes, at first you could only get the exhaust cam
Yes, I know the intake cam is the MIVEC cam, and I know you could only get the exhaust cam early on, but no, the intake cams were not just released recently - TurboTrix had theirs a long time ago. Other companies have just started to release theirs.
Old Nov 12, 2006 | 10:52 AM
bizzarro's Avatar
yes
Old Nov 12, 2006 | 10:53 AM
bizzarro's Avatar
so you say theres no prob with my setup?could you guide me to find where the problem is?
Old Nov 12, 2006 | 10:56 AM
Warrtalon's Avatar
The setup should be fine, but I don't know what's wrong with the car. That should be diagnosed by the tuner/installer. Something had to go wrong during the installation of the cams or something.
Old Nov 12, 2006 | 11:01 AM
bizzarro's Avatar
when you something what do you mean ,what could have gone wrong,although hes a good mechanic he doesnt know much of evos ,so if theres anything you can think of by your experience that could help me ,i would aprecieate very much ,thanks again for your time
Old Nov 12, 2006 | 11:11 AM
Warrtalon's Avatar
Could have put the cam caps on backwards causing a lot of knock, which is killing the power. There's lots of things that can go wrong with a cam install, especially on a IX with MIVEC. I wouldn't have gone to someone who doesn't have a lot of experience with Evos.
Old Nov 12, 2006 | 11:17 AM
bizzarro's Avatar
ok thanks again ,i know i rushed
Old Nov 12, 2006 | 11:31 AM
bizzarro's Avatar
but im not quite clear with the knock you mention ,the car runs and idles perfect ,although he broke what it was supposed to be some kind of plastic cap for the mivec sprocket,are these the ones you refer to?i already sent for it
Old Nov 12, 2006 | 11:41 AM
Warrtalon's Avatar
The knock would occur at WOT under boost - your idle would likely be fine. If it runs perfectly, then you wouldn't have lost 30whp, so I don't know how true that statement is. I don't think the plastic cap matters, but maybe...I guess you'll find out.
Old Nov 12, 2006 | 11:49 AM
bizzarro's Avatar
ok thanks again ill have it checked ,and your right otherwise we wouldnt be having this conversation,sorry bout that anyways thanks
Old Nov 12, 2006 | 11:59 AM
EvoHung's Avatar
can the evo make decent power with just one cam?
Old Nov 12, 2006 | 12:46 PM
Warrtalon's Avatar
It can make great power with the stock cams. Adding just the exhaust cam has shown to do very little, but the IX can still make great power.
Old Nov 12, 2006 | 12:50 PM
EvoHung's Avatar
Yes everybody knows the Evo can make great power with the stock cams. But can it make decent power with just one cam. I am not just speaking of the IX but also the VIII.
Old Nov 12, 2006 | 12:56 PM
Warrtalon's Avatar
I don't know if anyone has tried it on the VIII, because it makes no sense to do it. Doing both cams is so lucrative that doing just one cam really is a waste of time and effort.
You said you know the Evo can make great power with stock cams, so why are you asking if it can make decent power with one cam? If it can make great power with stock cams, then it obviously can make great power with one upgraded cam - it just won't make much more power than stock cams.
Old Nov 12, 2006 | 01:04 PM
EvoHung's Avatar
Your information is irrelevant to my question. The evos stock cams are tuned to be street and smog friendly. Whey would I want to upgrade just one cam? Maybe that is just a question that hasn't been covered by anyone. If you're the only person on this site right now trying to anwser peoples questions then I'm outta here. You are wasting my time.
