Weird noise from the engine while driving in the rain!
Old Nov 22, 2006 | 02:27 PM
03redtype-s's Avatar
when it rains here i notice my downpipe rattling more. Dont know why but it does
Old Nov 22, 2006 | 05:26 PM
Dade County's Avatar
This is so weird... I am having the same problem too. Just out of the blue it starts like making this crazy loud like rattling for about 5-10 seconds and then just goes away. You think it may be the same on my car also?
Old Nov 22, 2006 | 06:46 PM
evrblazin's Avatar
I have the same issue. I assumed it was an exaust leak with water coming in somewhere near the cat. Good to hear i'm not the only one.
Old Nov 22, 2006 | 07:51 PM
I thought that it was the fan or something because it sounds like the rythym of a fan as the noise stops. I am not sure what it is, but I am going to get it on a lift saturday to check things out. Have you tried to tighten any bolts or nuts or anything? I planned on changing my downpipe on saturday anyway. Good timing, as long as the other noise gets fixed. Let me know what you have tried or what you have found. Talk to you later, Dade.
Old Nov 22, 2006 | 08:40 PM
kmcconn9's Avatar
I have this same issue in the rain. I am going to remove the front tie bars and see what happens then....
Old Nov 23, 2006 | 06:40 AM
let me know if you have any other ideas of what it could be. thank you.
Old Jan 26, 2012 | 02:59 PM
freethriftyz's Avatar
Yeah, holy thread revival I know...and I don't even have the same car...but my X does this!! Whenever it rains hard is sounds like I have water in my engine and makes this horrible metallic scratching sound that just vanishes and can never be replicated but scares me sh!tless. I have a STOCK dp, but do have a test pipe. Sounds like the engine bay though...I am tuned. HELP!
Old Jul 18, 2012 | 08:46 AM
TomsSound's Avatar
Happens to me as well..
I've always thought it was a Differential noise.
I'm not an expert on differentials.. but for some reason it always felt like something was locking.. kinda like a differential.
I have an 03 VIII.
HKS Intake... UR Test Pipe and B&B Exhaust and Helix DP.
Old May 28, 2013 | 08:53 PM
CavinessEVO9's Avatar
I've had this issue for a while in the rain and recently started doing it even when it's dry out. I tried a few different things and even really thought it was all from the drive shaft but today swapped out the exhaust hangers with the same style from auto zone and all the noise/vibration has finally ceased! They are about 1CM longer and allows the exhaust to hang down just a tad more and off the undercarriage. I suggest trying this as it is pretty simple and cheap and in my case, has solved the issue so far. Will repost after next good rain
Old Oct 26, 2013 | 01:19 PM
boy36's Avatar
Hi I have EVO X and the same problem.I have AMS downpipe,test pipe and Miltek exhaust.Anybody resolved that problem? Thanks.
Old Oct 26, 2013 | 02:12 PM
barneyb's Avatar
What's happening is the hot exhaust is hit by water thrown up and warps.
babaz7
Dec 2, 2016 03:25 AM
Lancerfry30
Nov 14, 2016 11:25 PM
MyronGainz
Jul 17, 2015 08:57 AM
eddy5201314
Apr 3, 2014 03:25 AM
edIT
Mitsubishi TC-SST Discussion
Oct 8, 2013 06:16 PM
