im in need of help...
Old Nov 13, 2006 | 11:19 PM
ddubdb3's Avatar
ok i have a 06 mr and yes i wanted the cool noise and wasted money on a bov that is not needed the greddy rs. i think i had it adjusted to tight but i started to notice my gauge wasn't showing full boost 1.3 bars...so i took it off and put the stocker back on. i still have the problem. full throttle i get a bouncy 1-1.2 bars. i noticed the lower the rpm the more boost and as the rpms rise the more boost i lose. im goin to do a leak test on the ic piping this weekend but if anyone thinks its something other than a leak pllleaase let me know. thanks!
Old Nov 13, 2006 | 11:27 PM
srt2evo9's Avatar
did u reset the battery...you should probably do this everytime after you mess w/something on the car....
Old Nov 13, 2006 | 11:29 PM
ddubdb3's Avatar
what do you mean reset the battery? and isnt the gauge is mechanical so would that do anything
Old Nov 13, 2006 | 11:44 PM
andyktlee's Avatar
Pocket Mo
Just pull off the negative terminal of your battery and leave it off for 30 seconds or so to reset the ECU.
Old Nov 13, 2006 | 11:46 PM
ddubdb3's Avatar
do you think this will fix the problem?
Old Nov 13, 2006 | 11:51 PM
andyktlee's Avatar
Pocket Mo
It may or may not. It won't make the problem worse so it's worth a try.
Old Nov 13, 2006 | 11:57 PM
srt2evo9's Avatar
it could be something as simple as this might as well get the little stuff out of the way first
Old Nov 14, 2006 | 12:04 AM
ddubdb3's Avatar
yea ill try this i hope it works. if not could these symptoms be a leak...this is my first turbo car soo yea
Old Nov 14, 2006 | 12:05 AM
andyktlee's Avatar
Pocket Mo
Certainly could.
Old Nov 14, 2006 | 12:09 AM
srt2evo9's Avatar
yeah just for future refrence pretty much anytime you change somethin out you should disconnect the negative terminal
evrblazin's Avatar
lol.. good point
