Espilir JGT 500
Old Nov 27, 2006 | 08:40 AM
  #31
Flybert's Avatar
Originally Posted by djscoto
My greatest fear is putting on an exhaust and having it sound like a cheap civic. I hate that high pitch sound. Thanks in advance.
Is your EVO somehow naturally aspirated? If not, why would you worry about it sounding like a civic?
Old Nov 27, 2006 | 12:32 PM
  #32
Jeff1121's Avatar
Originally Posted by Zmann42087
Actually, this is a pretty common problem with EVO's in general (not just those running the JGT500R exhaust). The easiest fix is to buy a heat shield to protect your rear bumper.
my exhaust hangs so close to the bumper i couldnt even fit the shield (i have already looked into it)
Old Nov 27, 2006 | 03:19 PM
  #33
Zmann42087's Avatar
I had this same problem with my DSM a couple months ago; my Apexi N1 cat-back exhaust didn't stick out far enough, and infact wasn't low enough either. The exhaust tip on my N1 ended a couple inches before the rest of bumper did, and was high enough that it was actually touching my rear bumper.
Unfortunately, I didn't have the luxury of model-specific heat shields being available for my Eclipse like you EVO guys do. Instead, I used other means to fix the problem.
The first thing I did to remedy the problem was to replace my stock downpipe and my (aftermarket) test pipe with a full cat-delete downpipe from Road Race Engineering. The downpipe I ordered from RRE actually served a couple purposes... the RRE downpipe has a larger diameter than the restritive stock downpipe, thus decreasing power-robbing back pressure. More importantly, the RRE downpipe is longer than the stock downpipe/test pipe combo I had on the car. Because the RRE downpipe is longer, (obviously) it allowed the entire exhaust system to slide back a couple inches, thus increasing the rear bumper clearance.
Note that I'm not suggesting/reccomending you go about replacing your downpipe for the sole reason of pushing your exhaust system back. I did it because I needed the increased exhaust flow there anyway, so it was the logical place to add a couple inches to my exhaust system. Instead of replacing your whole downpipe to add length, I suggest adding spacer(s) somewhere along your exhaust system or maybe replacing your catalytic converter with a slightly longer one.
After I installed the RRE downpipe, the exhaust tip clearance was definitely improved, but it still wasn't far enough away from my bumper. In paticular, the exaust tip was sitting too high. I decided the easiest way to lower the exhaust tip was to replace the last couple exhaust hangers. I made a quick trip to my local Autozone, and picked up exhaust hangers that were longer than the ones I had on my car. Basically, I bought hangers that dropped the exhaust tip farther away from the exhaust hook on the chassis, and thus farther away from my rear bumper.
With these two simple modifications, I was able to move the exhaust tip back 3" and down 1.5". Doing it by myself, it took me one Saturday afternoon (about 4 hours). Assuming you have access to a car jack, jack stands, household tools, and some WD40, you should be able to do it by yourself. I consider this an afternoon well spent, considering I saved my rear bumper from any (more) damage, and opened up a little exhaust flow in the process. Hopefully you find some of these suggestions helpful. Let me know if you have anymore questions.
Old Nov 27, 2006 | 04:29 PM
  #34
Jeff1121's Avatar
i am happy with my BR 2.5 dp and rnr test pipe, it is not melting the bumper (anymore), but i am thinkin bout having my buddy weld an extention to the exahust hangers to help it hang lower...we shall see
Old Nov 27, 2006 | 06:59 PM
  #35
Zmann42087's Avatar
... that sounds like a good idea too.
hksevoix
Apr 27, 2007 12:51 PM
nyaegermeister
10
Jun 8, 2006 11:59 AM
Black1105
Apr 30, 2005 05:31 AM
WorldONE
34
Mar 30, 2005 07:05 PM
WorldONE
74
Apr 7, 2004 09:47 PM
