newbi, evo issues?
Old Nov 20, 2006 | 07:05 AM
BlackonBlack2's Avatar
newbi, evo issues?
Driving to school today, and didn't get a chance to let the car warm up, but didn't use the turbo on the way there.
All of the sudden battery light came on, and brake light came on same time? i thought most like need to get the battery replaced (but the car has only 12222 miles), and when i was drive back, all the lights came on; tramac, gravel, and snow, as well as the brake and battery light, it wouldn't let me choose tramac only? After i got home, left the car off for 5-10 mins, and then turned it back on, and everything was working normal?
I don't have any mod's.
wasn't sure if this was an issue? could it be the ECU? have no idea whats going on with the car? bought the car preowned at 7k 3-4 months ago
Thanks
Old Nov 20, 2006 | 07:11 AM
onefast4dr's Avatar
Take it to the dealership, theres a problem with the ACD system. Theres a lot of threads on this same topic. Try searching "ACD problem"...I know that at least a few helpful threads will come up.
Old Nov 22, 2006 | 07:11 AM
rodrig.diaz3's Avatar
Thanks
What did you do finally????
Old Nov 22, 2006 | 07:37 AM
PessimiStick's Avatar
All three ACD lights is a fault code from the ACD ECU. I'd get it looked at.
Old Nov 22, 2006 | 09:31 AM
AlphaMale's Avatar
From: Michigan, Indiana, depends on the time of day.
but how does that explain the battery and brake light?
I've noticed in a lot of mitsu's when the alternator or battery is dying all the dummy lights will start lighting up.
either way, keep us updated!
Old Nov 22, 2006 | 09:37 AM
I suppose that is possible as well (bad voltage making the guage cluster flake out), either way, I'd get it checked. =D
Old Nov 22, 2006 | 10:36 AM
Kay@kacework.com's Avatar
brake light and battery light is usualy the alt. 9 times out of ten in cars from Japan......
Old Nov 27, 2006 | 11:07 AM
Took it mitsu dealer ship, (rick case) they suck BEEEP, they told me the ACD light is comeing on because the battery is dying, they kept my car for 6 hours and told me that the battery was low, so i'm going to take it to another dealer ship, but the ACD light has been stayn off so i'll wait tell it comes up again
Old Nov 27, 2006 | 11:19 AM
Turbo Meg's Avatar
I had the same issue with only 6500 miles. I replaced the battery and have not had any more issues. Not worth spending hours at the dealership or potentially getting stranded miles from home. A good battery is a good investment.
Old Nov 27, 2006 | 11:21 AM
chaz517's Avatar
Well once this hapend 2 me but I realized I never tighted the little metal connection on the battery and it popped on and off real quick, and all 3 of my acd lights cmae on, so I pulled over and tightened it down and never looked bak good luk
