boost ?
Old Nov 29, 2006 | 12:14 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Originally Posted by srt2evo9
i was askin of i should do a boost leak test or if its normal to taper that much before i do one
the first guy suggested doing a boost leak test. A boost leak test should be the first thing you do to diagnose engine problems(unless they're obvious) since they can cause so many issues. Poor idle, excessive taper, rich afrs(or lean at idle) to name a few. Do a boost test.
Old Nov 29, 2006 | 12:16 PM
Originally Posted by PessimiStick
I was just bein a dick. =p
Your explanation is fine though, I have _PessimiStick on a different forum for similar reasons.
i know you were . no harm no foul.
srt2evo9's Avatar
i suggested it jesus is it that hard to get a straight answer... Is it supposed to taper that much or no...
Old Nov 29, 2006 | 12:19 PM
dont know, my 8 didn't that much when i was on the stock turbo. My 35r controlled by aem holds 23 psi right till 7k
Old Dec 8, 2006 | 10:03 PM
srt2evo9's Avatar
ok so just got around to doin a boost leak test and the results were....there wasnt a leak to be found anywhere! Dammit
Old Dec 8, 2006 | 10:12 PM
Warrtalon's Avatar
Not surprising, considering your taper is normal for a IX.
Old Dec 8, 2006 | 10:17 PM
srt2evo9's Avatar
23 to 17 normal?
Old Dec 8, 2006 | 10:21 PM
Warrtalon's Avatar
Yes, IXs taper more than VIIIs due to the MIVEC pushing more through the head than the turbo can keep up with. You still make lots more power than an VIII maintaining 19psi - people spend WAY too much time worrying about "boost taper" and too little time worrying about how the car actually performs (i.e. track and dyno).
Old Dec 8, 2006 | 10:24 PM
srt2evo9's Avatar
well it performed like **** at the track thats kinda why i was abit worried about... that and every other IX in tucson seems to be holdin 19-20
Old Dec 8, 2006 | 10:26 PM
Warrtalon's Avatar
People claim that all the time. If they show you MAP sensor logs of their IXs with 20psi at 7000rpm, then you can believe it. If and when that happens, please post them here for me to see...
if it performed poorly at the track, then log it next time to see what your AFRs and timing are doing all the way through 4th.
Old Dec 8, 2006 | 10:33 PM
Evo_Jay's Avatar
+1
Old Dec 8, 2006 | 10:40 PM
srt2evo9's Avatar
ill have to do that didnt think there'd be any issue with the Dynoflash tune but ill give it a try
Old Dec 8, 2006 | 10:46 PM
Warrtalon's Avatar
I didn't say it would be the tune - that's another thing that people automatically assume. Just because the car may be running poorly, it doesn't mean it's because of the tune. Tracking the AFRs and timing is not for determining the quality of the tune - it's for finding symptoms of why you're not running as well as YOU expect (if that's the case). It may end up pointing to the tune, but don't assume that up front.
Old Dec 8, 2006 | 10:50 PM
eponti's Avatar
did your car taper that much when it was stock?
Old Dec 8, 2006 | 10:53 PM
srt2evo9's Avatar
well if there are 0 boost leaks the boost was the same as when tuned with the same gas(i only use one station) why would the A/f's timing/ knock be out of whack other then a tune?? Not bein a Dick Just honestly wondering...
