Staggered wheel setup on an Evo? A no no?
Old Dec 4, 2006 | 07:21 AM
Ultimate CC's Avatar
Its not an issue to run wider in the front then back on 03-04 but the 05s with acd this combo doesn't really help the car much...
Old Dec 4, 2006 | 08:59 AM
Sap12687's Avatar
If i had the choice to put the wider wheel in the back i'd like to but i do not want to go through another t-case and would never sacrifice my cars performance for anything aesthetic. I'd like to come to a conclusion as to if this is appropriate or not. Im not worried about tires. The only difference in tire will range in width.
Old Dec 4, 2006 | 09:19 AM
donour's Avatar
Talk to somebody that has actually tried it.
https://www.evolutionm.net/forums/sh...d.php?t=135354
d
Old Dec 4, 2006 | 09:21 AM
JoizeeX's Avatar
how's that not an issue, 03-04 have a viscous center diff, the fluid in it will wear out much faster if you run different circumference tires front to back because it'll be constantly heating up from unnecessary friction.
Old Dec 4, 2006 | 09:22 AM
look at any of the top time attack cars in japan, all run wider fronts then rears, makes the car handle much more neutral...
Old Dec 4, 2006 | 09:40 AM
Jean's Avatar
MY rims have a different offset in the back. Same size rim and tire it just looks as if there is a larger lip in the back.
Im not sure if he was interested in just looks or if there was an actual performance gain from doing so.
Front
Back
Old Dec 4, 2006 | 10:01 AM
Torre from Va.'s Avatar
Steve the answer to your question is in the link below, Thanks !!
https://www.evolutionm.net/forums/sh...d.php?t=219378
Old Dec 4, 2006 | 10:32 AM
EvoIX_thousand's Avatar
Once and for all... tire WIDTH has NOTHING to do with your drivetrain, transfer case, differential(s), ect. It is all about OVERALL CIRCUMFERENCE of the tire. Even the diameter of the rim has nothing to do with it as long as the overall wheel+tire diameter is equal all the way around. If you go with wider tires in the rear, you need to make sure you also go with a lower aspect ratio in the rear to copensate. You could even go with a 17" rim in front and an 18" rim in rear as long as you went to a lower profile rear tire to equal the diameter of the higher profile front tire. You can figure all of this out on a calculator. Some places like Tire Rack even have the overall diameter listed for each size of tire they sell. As far as your drivetrain goes, it is all about running the same overall tread diameter all the way around the car. This will make all four wheels rotate at the same speed when driving straight. Drivetrain damage will only occour if the wheels rotate at different speeds for an extended period of time.
Handling however, is another story.
Old Dec 4, 2006 | 12:53 PM
Sap12687's Avatar
Thanks everyone. I've got my answer.
Old Dec 4, 2006 | 10:34 PM
barneyb's Avatar
You also need to keep the tire centered over the wheel bearings or you risk wheel bearing damage or sheared wheel lugs.
I was at the local Ford dealership several years ago when they brought in a van that was being driven on the interstate by two young men before it wrecked. They were running wheels with large offsets and all five studs on the passenger front wheel sheared off. The van flipped killing the driver.
Old Dec 4, 2006 | 10:47 PM
V.8MR's Avatar
I've got a set of CE28's exactly like evasive on order. Itl take 3 months to get them though.
Old Dec 5, 2006 | 11:24 PM
signalauto27's Avatar
18x9.5 +15F +28R coming soon....
Volk CE28n. I can't wait to post pics.
Old Dec 13, 2006 | 11:57 PM
Sap12687's Avatar
What numbers are taken into consideration when looking at the wheels aspect ratio?
eliminator 429
Nov 23, 2016 09:45 AM
eliminator 429
Mar 30, 2016 05:47 PM
5 ltr. beater
Jan 30, 2011 04:04 PM
J8dailo
Aug 1, 2008 12:21 PM
MAmorn
Sep 21, 2004 01:04 PM
