Daily Driven Evo
Old Dec 20, 2006 | 08:00 AM
  #46
Kayaalp's Avatar
Originally Posted by gsrboi80
Originally Posted by SkylineMyth
Would you say the mobile 1 is better than a full synthetic engine oil?
It is a Full Synthetic motor oil
Technically, it's not. It's a semi-synthetic. It's fine to use on the street; lots of detergent to keep the engine clean. There are better choices for track use.
Emre
Old Dec 20, 2006 | 08:18 AM
  #47
gsrboi80's Avatar
Mobil 1 Fully Synthetic is Fully Synthetic 100%
Mobil 1 High milelage and extended life are not.
Just FYI
Old Dec 20, 2006 | 08:23 AM
  #48
Kayaalp's Avatar
It does not use 100% synthetic base stock. It uses purified petroleum as a base stock...which means it's not a true 100% synthetic oil. Look at the base stocks used in Motul 300V for example.
Just FYI.
Anyway, it's not that big a deal. I still use Mobil 1 on the street. I just use real synthetics on the track (I like Elf Excellium these days).
Emre
Old Dec 20, 2006 | 12:56 PM
  #49
SkylineMyth's Avatar
Just FYI.
Emre
that's cool
Old Dec 20, 2006 | 01:11 PM
  #50
OneillEvo's Avatar
So what I am getting from reading all this is...
Unless your racing or aggressively using your EVO just maintain it like a normal car. Just things tend to go out quicker. Correct?
Change Oil regularly
Check and or rotate tires when needed
Replacee Plug and or wires when needed
Check fluid levels
Check belts and hoses often
Old Dec 20, 2006 | 01:14 PM
  #51
Tsurugi-san's Avatar
Your floormats will wear out faster than your tires! Budget that in, too!
Old Dec 20, 2006 | 01:18 PM
  #52
Box Rocket's Avatar
I service mine per the book (owners manual). 40k and counting. nothing unusual. the clutch will only give up the ghost quickly if you a) can't drive or b) launch regularly.
Ditto. I also service mine according to the owners manual. I am convinced that there are TONS of evo owners out there that just don't know how to drive or are at the track every weekend. I'm still on the stock clutch at 50K, as well as the original brakes. I'll probably be doing the brake pads in the early spring but I'm been very happy with how everything on my car has held up. *except for the paint* f-ing rockchips!
Old Dec 20, 2006 | 01:26 PM
  #53
Gary 805's Avatar
thank god for cut and paste??
well on the real side. i personaly go through the following.
-Spark Plugs and Oil change every 3k miles.
Plugs Gapped @ 23 BPE8 series
-Normal fluids. Check the tranny fluid and Clutch/Brake Fluid
-Brakes & Rotors
-Wash The Car
-Tires. Get them balanced rotated and all every other month.
my car runs fine.
Old Dec 20, 2006 | 04:26 PM
  #54
kilgoja's Avatar
you change your spark plugs every 3k?....that's a bit unnecessary....you don't have to change them until like 60k...most cars they last 100k+
Old Dec 20, 2006 | 04:46 PM
  #55
bone's Avatar
mines gonna be a daily driver, i also hope i dont have to change plugs every 3K miles. WOW. i thought i read the manual and didnt see that. will reread. thanks
Old Dec 20, 2006 | 05:44 PM
  #56
sammyKiller's Avatar
-Brakes & Rotors
-Wash The Car
my car runs fine.
3k for plugs and balanced every other month = overkill
Old Dec 20, 2006 | 05:58 PM
  #57
QuickSilver2's Avatar
-Brakes & Rotors
-Wash The Car
my car runs fine.
I commend you for going the extra effort. It's all good unless it has an adverse effect on the engine/car.
Old Dec 21, 2006 | 05:58 AM
  #58
Aluma's Avatar
I'm with Boxrocket on this one...dang rock chips! :P
Old Dec 21, 2006 | 06:32 AM
  #59
speedfreak0920's Avatar
BRAKES! rotors and pads. rotors through mitsu are like 250 a piece!!!! i think maybe even more? tires too.
Old Dec 21, 2006 | 07:54 AM
  #60
Chemwarrior's Avatar
I concur with the dang rockchips. It seems that I have a new ding in my paint every week and this is just with normal around town driving. I have the paint pen and that helps some what, but it's just not the same as having a smooth as glass paint finish.
