Is this normal? (stock advan tires)
Old Jan 7, 2007 | 12:50 PM
  #31
Autoxevo's Avatar
^+1
Are you using the parking brake? Every time I wash my car and set the parking brake it locks up (my drive way is slopped so it's the only time I use it). Have to pop clutch to get it free. One time I parked the car for 2 months and holly sh*t was it hard to move.
Go forward! I found it broke free easier
Old Jan 7, 2007 | 12:54 PM
  #32
Evo Tengoku's Avatar
not much room for me to go forward but ill try
Old Jan 7, 2007 | 01:04 PM
  #33
*sigh* can i put WD-40 on my rotors?
Old Jan 7, 2007 | 01:14 PM
  #34
Autoxevo's Avatar
I dont think you'd what to get that stuff on the pads, can you have someone else use there car to pull you backwards with a tow strap? Maybe enough so that you have more room in front of you to try going forward? Try rocking the car.
Old Jan 7, 2007 | 01:30 PM
  #35
do the back rotors stick only or fronts?
Old Jan 7, 2007 | 02:11 PM
  #36
Autoxevo's Avatar
could be all 4 and the ebrake
Old Jan 7, 2007 | 02:19 PM
  #37
theEVOdream's Avatar
Originally Posted by 3SgteGuru
Thats from the small amount of corrosion that builds up on the rotors when they get wet.
+1 I get it everytime it rains and then dries up
Old Jan 7, 2007 | 02:27 PM
  #38
eve-slow's Avatar
Can you see your pads stuck on the rotors?
Old Jan 7, 2007 | 02:39 PM
  #39
....... im ok now. thanks everyone
Old Jan 7, 2007 | 02:58 PM
  #40
cfdfireman1's Avatar
Rock it and don't spray the rotors PLEASE!
Old Jan 7, 2007 | 03:29 PM
  #41
any tips to prevent this from happening again?
Old Jan 7, 2007 | 03:39 PM
  #42
96_LXR's Avatar
My VIII does this alot. It is worst if you wash the car, pull it in the garage and let it sit through the weekend.
When you try to back up it totally feels like something is locked up. I will ususally try to roll forward just a little, then try and back up.
When it does break free you will hear a little noise.
The brake pads have some metal in them and the rotors rust really quickly (good material).
My car will also do this after driving in heavy rain and then parking overnight.
Just another Evo quirk!
Old Jan 7, 2007 | 03:42 PM
  #43
4G63's Avatar
Nothing to stress about...its just the parking brake sticking after being released. Happens if they get wet and sit for a while!
Old Jan 7, 2007 | 03:59 PM
  #44
96_LXR's Avatar
When I was trying to isolate what was going on I washed the car, parked it in the garage and put a block behind the wheels and left the parking brake off.
Still did it the next day, it only happens on my car if the rotors and brakes are really wet when you park it.
Just my $.02
Old Jan 7, 2007 | 06:52 PM
  #45
If it really bothers you drive the car around the block after you wash it before you park it.
