works o2 housing
Old Jan 1, 2007 | 07:51 PM
Vigo's Avatar
I just did a search about the Invidia o2 housing. Someone with an Evo 9 MR had a problem fitting this o2 housing to the turbo side. He said the holes did not match up, but he got it to fit anyway and said he gained some power. I guess he got it modified to fit.
Old Jan 1, 2007 | 07:55 PM
EvoDan2004's Avatar
yes as i beleave b/r had the same problem. it did see gains in his test but i think it was the last amount of gains out of all the o2 housings he tested. the ebay o2 was the best one and the cheepest.
Old Jan 1, 2007 | 07:59 PM
fromWRXtoEVO's Avatar
I completely dismiss such claims. If there is one thing Works can bragg about is bulkyness(very solid built) and fittment. They spent hundreds of hours into this housing, the heat shiel fits like a glove and the mounting bracket also fits.
Carlos
Old Jan 1, 2007 | 08:01 PM
EvoDan2004's Avatar
Carlos
i also agree. fits like mitsubishi made the part for the car from the factory
Old Jan 1, 2007 | 08:04 PM
Warrtalon's Avatar
Carlos
Carlos, Vigo said the INVIDIA O2 HOUSING - you're talking about Works. The Invidia does have fitment problems, but Works does not...of course, neither does the regular SS O2 from Ebay.
Old Jan 1, 2007 | 08:05 PM
Originally Posted by evodan2004
maby when you got there d/p it required there 3'' d/p. but when i got mine i was sent this speacail like gasket that worked with the stock d/p. so maby at one point is was a must for there d/p but now i dont think it is. updated there stuff i guess
I completely respect your opinion and in fact I don't doubt it. I know for a fact that Works came out with their o2 housing with the market goal of having this unique 02 housing to fit exclusively on their own 3"downpipe.
I would not doubt for a split of second that they realized that it was much better profit wise to offer some sort of "gasket kit" that would allow you to fit their 02 hsouing to any other rerquired 3"size competitor downpipe. So your comments totally makes sense to me.
Carlos
Old Jan 1, 2007 | 08:06 PM
Thanks for the correction Clayton. Either way Clayton, I concur with your statements from page one, I rather would spent the money on a ebay unit plus some cams or alky.
Carlos
Old Jan 1, 2007 | 08:08 PM
EvoDan2004's Avatar
I would not doubt for a split of second that they realized that it was much better sales profit wise to offer some sort of "gasket kit" that would allow you to fit their 02 hsouing to any other rerquired 3"size competitor downpipe. So your comments totally makes sense to me.
Carlos
just for the record i was not snaping at you or warr. i was just letting the thread know that the work's housing will work with the stock d/p or any d/p that bolts to the stock o2housing. they send this odd looking thing that go's with the gasket somehow to make it work. but if you use there 3'' d/p then the adaptor part is no good.
Old Jan 1, 2007 | 08:13 PM
Off course you weren't. You are OK, we were just addressing some options here. You actually brought up a great benefitial point, you let everyone know that Works now offers this "gasket kit" that allows you to fit the Works o2 housing into any other 3"downpipe so my credit to you.
Carlos
Old Jan 1, 2007 | 08:16 PM
EvoDan2004's Avatar
i also agree the ebay o2 housing is the best bet. i was gonna switch to it but in a few mounths im putting a turbo kit on . not worth the change.
Old Jan 2, 2007 | 06:36 PM
Jakeg97's Avatar
Get the Invidia 2.9" o2 housing.
Invidia has a 2.75 inch size outlet
Old Jan 2, 2007 | 07:17 PM
Vigo's Avatar
Injected Performance says it's 2.9 inches at the outlet. Did you measure it yourself and actually came up with 2.75 inch?. On Lancer Shop's site it says the same thing.
https://www.evolutionm.net/forums/sh...d.php?t=233422
http://www.lancershop.com/customer/p...5&cat=0&page=1
Old Jan 3, 2007 | 07:14 AM
Jakeg97's Avatar
Old Jan 3, 2007 | 05:14 PM
Vigo's Avatar
Awesome, thanks!
Old Jan 3, 2007 | 05:18 PM
Spec'd's Avatar
To bad the SS-autochrome doesn't have a bracket for the heat shield.
