works o2 housing
Old Dec 31, 2006 | 04:13 PM
MRevolutionRed's Avatar
works o2 housing
i have been looking all over the place to find this o2 housing..can someone please tell me where to find it..thanks
Old Dec 31, 2006 | 04:20 PM
BigEd925's Avatar
Have you actually tried picking up the phone and calling works?
http://www.worksevo.com/store/produc...roducts_id=189
Old Dec 31, 2006 | 04:22 PM
t51splbb's Avatar
Edit: ^^^^^^ He beat me to it. Did you look on their website? Here you go.
Old Dec 31, 2006 | 04:59 PM
Warrtalon's Avatar
At Works, of course.
FYI, it costs $400+ (not much less than cams or alky injection), makes less power than an $80 SS o2, and requires a DP with a 3" flange opening.
Old Dec 31, 2006 | 05:03 PM
BigEd925's Avatar
haha 100% agreed, but its works
Old Jan 1, 2007 | 07:10 PM
Jakeg97's Avatar
but does use the oem mounting point and is built better
Old Jan 1, 2007 | 07:20 PM
Warrtalon's Avatar
Built "better"? Not sure what makes it built "better," but it does use the bracket, but that doesn't matter unless you choose to use a crack-prone tubular manifold that makes less power than the ported stock - and that is not a reason to spend $400.
Old Jan 1, 2007 | 07:25 PM
EvoDan2004's Avatar
no it does not require a 3inch down pipe. you can use it with the stocker if you want to.
Old Jan 1, 2007 | 07:29 PM
EvoDan2004's Avatar
and no it does not require a 3 inch flange opening d/p eather. they send you what is needed to make it work with the stock downpipe or any downpipe that will bolt up to the stock o2housing. make sence. probly not but all you need to know when getting this part is it will most likly work as long as your d/p now bolts the the stock o2 housing. and provided works sends the part needed to make it happen.
Old Jan 1, 2007 | 07:30 PM
Vigo's Avatar
Get the Invidia 2.9" o2 housing. It is also cast. It comes with a bracket that was designed for extra stability and support. It also includes the o2 sensor bung already welded in. This unit only cost $200.
Old Jan 1, 2007 | 07:33 PM
EvoDan2004's Avatar
dident b/r have big problems trying to get this to bolt to the car just to test it???
Old Jan 1, 2007 | 07:37 PM
fromWRXtoEVO's Avatar
I was one of the truly first customers to get one 3"o2 housing from works installed on my car.
It requires their 3"downpipe to make it work. I got mine for a special price but it was still very pricey. I got mine cheaper because I was on the waiting list for over a year.
I never increase significant power or torque. I suggest what Warrtalon told you, get yourself a set of cams or Alky, they will yield much much more power/tq per dollar spent. At first, the Works o2 hosuing was perhaps the most wanted item for anyone keeping the stock turbo, later on it was demonstarted that even smaller o2 housings were yielding even better results, in fact some Ebay $80 were outperforming other ones.
Your other option is to get a cheaper one. As far is getting the works, you can get them directly from them(worksracing). You have a few paths, you can go and buy the Works and spent $400 plus or you can listen to people like me that already went that path.
I don't want to give the wrong impression, I truly believe Works put the most R&D on this 02 Housing, perhaps more than anyone else but ultimately I believe the stock turbo works well with even 2.5" generic 02 housings.
My .2c
Carlos
Old Jan 1, 2007 | 07:39 PM
Vigo's Avatar
Really? Let me do a search.
EvoDan2004's Avatar
My .2c
Carlos
maby when you got there d/p it required there 3'' d/p. but when i got mine i was sent this speacail like gasket that worked with the stock d/p. so maby at one point is was a must for there d/p but now i dont think it is. updated there stuff i guess
Old Jan 1, 2007 | 07:48 PM
Jakeg97's Avatar
Built "better"? Not sure what makes it built "better," .
constructed stronger, has mounting points for heat shield, exceptional appearance
